Results 1 to 4 of 4
Thread: High Temp Powder Blistering
  1. #1
    txtaco's Avatar
    txtaco is offline Platinum Member
    Join Date
    Sep 2009
    Posts
    2
    Default High Temp Powder Blistering
    We purchased some silver high temp powder from pbtp and coated a set of 350 small block headers. The client brought them back to me and said the coating blistered up after 10 min of his engine running. The headers were sandblasted and cleaned with thinner. No Iron Phosphate was used. Any suggestions please?
  2. #2
    Harleydad's Avatar
    Harleydad is offline Metal Finishing Guru
    Join Date
    Dec 2006
    Posts
    833
    Default Re: High Temp Powder Blistering
    You shouldn't clean with the thinner either. When I do high temps' it's blast only, no chemicals. Don't handle the parts without nitrile gloves.
  3. #3
    txtaco's Avatar
    Join Date
    Sep 2009
    Posts
    2
    They were just wiped down with thinner before blasting to get all the grease off. After blasting they were just rinsed, dried, and preheated.
  4. #4
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Quote Originally Posted by txtaco View Post
    what did you rinse the header with ? i never water rinse steel parts.
    did you apply 1 or 2 coats of powder ? high heat powders don t work with multiple coats
Thread Information
Users Browsing this Thread
  1. High temp powder
    By goincrzy in forum Powder Coating Questions
    Last Post: 02-19-2009, 06:22 PM
  2. High TEmp Powder
    By Luck_E in forum Powder Coating Questions
    Last Post: 10-07-2008, 10:41 AM
  3. High Temp Ceramic powder
    By lfsracing in forum Powder Coating Questions
    Last Post: 10-06-2006, 11:10 AM
  4. High Temp Powder??
    By trsick in forum Powder Coating Questions
    Last Post: 10-11-2004, 08:25 PM
  5. Can I use VHT high Temp with Krylon High temp radiator paint
    By magnus in forum Other Metal Finishing Questions
    Last Post: 05-03-2003, 11:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
