Results 1 to 4 of 4
Thread: Carbon bicyle frame
  1. #1
    peter61 is offline Amateur Metal Finisher
    Join Date
    Jun 2007
    Location
    Southern N.J.
    Posts
    104
    Default Carbon bicyle frame
    Is it possible to powder coat a Carbon fiber bicyle frame?Has anyone ever tried it?
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: Carbon bicyle frame
    Doesn't sound like a good idea..... The carbon will take it fine,.... the resin that holds it together may not.
    EMAIL scott@scottrodspc.com
  3. #3
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    i did quite a bit of research on this a few months ago. my conclusion is that i now tell customers no. from what i read, whether it can be coated depends on the carbon's resin matrix. some can take it, some can't. plus, based on what a pita it is to even wet paint or liquid clear carbon with the massive pinholing, it'd probably have a big outgas issue.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  4. #4
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    i did a piece of tubing that was cut off from a scrap carbon fiber bicycle frame
    heated the part to about 200 f then i coated , cured at around 375 f .
    no outgasing on the part , finish was as nice as any other part that i do .
    i did not do any tests on the part after the coating but the piece of tubing seemed to be a little more flexible than it was before .
    i would not want to do a complete frame and find out later that the heat ruined the fiber or the resin
Thread Information
Users Browsing this Thread
  1. Carbon Fiber looking powder?
    By Deecoat in forum Powder Coating Questions
    Last Post: 04-19-2008, 08:44 AM
  2. ever powder coated bicyle pedals?
    By FigureLLC in forum Powder Coating Questions
    Last Post: 11-19-2007, 09:33 AM
  3. Stainless to look like carbon?
    By snoopygolf in forum Other Metal Finishing Questions
    Last Post: 06-12-2006, 11:52 PM
  4. carbon fiber
    By hulk30 in forum Caswell Please Sell This...
    Last Post: 04-20-2006, 09:50 PM
  5. carbon steel sword
    By DavidLen in forum Metal Polishing Questions
    Last Post: 08-23-2002, 04:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
