Results 1 to 3 of 3
Thread: Powder on frame welds
  1. #1
    peter61 is offline Amateur Metal Finisher
    Join Date
    Jun 2007
    Location
    Southern N.J.
    Posts
    104
    Default Powder on frame welds
    I've been doing a few motorcycle and bicycle frames lately and I had some trouble with the powder sticking to the welds,is this a common problem?The rest of the frame takes powder very nice.
  2. #2
    mtg125 is offline New User
    Join Date
    Jul 2009
    Location
    south of ST. LOUIS
    Posts
    20
    Default Re: Powder on frame welds
    Try warming the part up to about 120 degrees and shooting your welded areas 1st. Also make sure the welds are extremely clean.
  3. #3
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    it's not a matter of the welds not accepting the powder. where two tubes come together in the corner you get a faraday cage. basically, and electrical field that repels the powder out of the corner. if your gun is adjustable, turn the kV down as low as it will go. shoot the tough to get corners first. try turning the powder flow up for the corners. try varying the gun-to-part distance in the corners. try pulsing the trigger (short bursts) in the corners. and if all that fails, hot flock it (shoot it hot... i like to do it at 225 degrees... the powder should stick, but not completely melt).
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
Thread Information
Users Browsing this Thread
  1. Sanding the Welds on Frame to get it ready for Polishing
    By Badboy23 in forum Metal Polishing Questions
    Last Post: 04-23-2009, 08:04 AM
  2. How much powder does it take for a atv frame?
    By pcer in forum Powder Coating Questions
    Last Post: 12-08-2007, 08:37 PM
  3. how much powder for motorycle frame?
    By tattoo72 in forum Powder Coating Questions
    Last Post: 02-18-2006, 12:01 AM
  4. powder coating a frame?
    By randygrapes218 in forum Powder Coating Questions
    Last Post: 06-25-2004, 08:24 PM
  5. How much powder for ATV frame
    By senna-the-great in forum Powder Coating Questions
    Last Post: 03-07-2004, 07:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
