+ Reply to Thread
Results 1 to 5 of 5
Thread: Noobie here with some question.
  1. #1
    Default Noobie here with some question.
    Hello everyone,
    I am new to the PC process. I am an avil snowmobilier and i want to PC some of the parts on my sled. Some steel and some aluminum. My family owned busness allows me access to large ovens and and beadblasting cabinet so i figured it would be cheaper and more put to do my own PC. Some of the aluminum parts i want to PC on the sled are the head cover and brake caliper. Maybe some exhaust parts. Do i need to take special care when PC
    these aluminum parts because of the 400* temps?
    thanks.
    Share with Facebook
  2. #2
    Join Date
    Jul 2009
    Location
    south of ST. LOUIS
    Posts
    19
    Default Re: Noobie here with some question.
    Quote Originally Posted by doug1991 View Post
    Hello everyone,
    thanks.
    if you are worried about the temps, check out powder buy the pounds Ral colors, I believe they cure at 340 degrees for 10 minutes, at that temp it should not effect the metal at all. even at 400 I have never had an aluminum part fail, you wouldnt want to do it a bunch of times but once you should be fine.
    Share with Facebook
  3. #3
    Join Date
    Nov 2005
    Posts
    945
    i wouldn't do the exhaust parts in powder, maybe with the exception of the muffler.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
    Share with Facebook
  4. #4
    OK. Thanks for the information guys. Also i bought a HF gun for about 70 bucks. I only got that one because of a few reviews i read online. Is it really **** and should i return it for a different one? At this point its only going to be a hobby.
    thanks
    Share with Facebook
  5. #5
    I have the harbor freight gun two craftsman guns and just ordered a hyper smooth
    The harbor freight gun can be modded to work well using a hopper if you want to search the forums for gun mods should come up with all sorts of stuff and ideas to make it work better
    That said it didnt work to bad out of the box but way better after mods
    for what its worth Im new
    Josh
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. noobie questions
    By j4str in forum Electroplating Questions
    Last Post: 03-20-2009, 06:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
