I want to PC some suspension parts on my sled and was told to use low temp powders. Thoughts on this?
I was told the cure temps could effect the strength of the aluminum. Im not
sure if thats true.
Your fine with regular powder, the amount of time those parts are at cure temp is minimal. You could also cure at a lower temp for a longer time. If it really concerns you there are some low cure powders out there.
Doug,
Some aluminum and steel alloys are very sensitive to higher temps.
Good luck
