Top to bottom:
top one looks ok,.... can't tell mcuh about it but I'll bet, even though it's not visible in the picture, it suffers from similar problems the others have.
next one down, looks to have a good coat of powder. Appears to have some prep issues. Otherwise it looks OK.... may also suffer from undercure just a little.... not really clear in the picture.
next one down is the extreme chrome..... That piece appears to have a pretty bad case of substrate contamination. Wasn't prepped properly maybe. It also has the same undercure appearance the "good" purple part shows, but much more severe. There is a possibility there's some overtemp also. I'm not as familiar with the results achieved by overtemp, so that could be what causes the pieces to look poorly prepped.
The last one looks to have a case of Back-Ionization on the second coat. The little "pock marks" are evidence of that. Basically the part is not well grounded and the excess charge is not draining off any, or enough during the second coat. Typically due to a weak ground. Usually caused by the first coat, covering the part where it is hanging.
Temp control is vital to the curing process, so getting that part addressed is paramount to getting your coating to be uniform.
Prep is the heart of all coatings, be it wet paint, ceramic, powder, chrome plating, etc.... Once the part is celaned, stripped, celaned again with compressed air, run a torch over it for dust bunnies,.... Should not be touched with human skin again before the coating process.... It doesn't look like any of these suffer from handling issues. They appear to have Prep, and curing issues.
Once you get the base coat cured properly, the second coat will not affect the first coat so much. It certain ly shouldn't "lift".
Once you get the basics down, the custom colors will be much easier. I have one color that beats me to death with issues almost everytime I use it. And I love the color. It's a good thing no one is asking for it on their stuff as customers. Jollipop Copper Orange. If I ever master that one, the rest will be silly simple.
I've been coating for just under 2 years now, and I'm by no means THE authority, but the above is a reflection of my experience, and is just my opinion. Others may chime in and disagree.
LinkBack URL
About LinkBacks
