Assuming that the items that you would want to bead blast are not overly large, the H.F. Blast cabinet is a good choice. I've had one for more than ten years that I got as a demo for $150. I've made a few changes: I added a Snap-on blast gun which has tungsten carbide inner and outer tips as well as a tempered glass window with a replaceable polycarbonate sheet. I also modified the glove mounts to permit more arm room and also so that I could easily mount the $5.00 H.F. blasting gloves.
I also installed three CFL lamps with glass covers to potect them. I use a vintage Cyclone Brand dust collector to keep the field clear when I'm working. It is a real performer. It holds 50 pounds of whatever media you are using. I use med. fine glass beads but i've used walnut shells and soda in the past. It's a lot of work to change media, though, so I just use glass beads nowdays.
With the proper media, your metal will be on its way to a nice powdercoat job. It's really amazing how well a blast cabinet works. By the way, do you intend to use real sand? I have a separate Blast Brand pressurized unit for that. I use it outside with a hood and I don't try to recapture the sand. Sand would be entirely too harsh for anything that I would use the cabinet for.
You could easily build a cabinet with some 16 ga. sheet metal but even that is not cheap anymore. It cost me $300 for all of the metal to build my 2 X 4 X 6' oven.
An important factor is the size of the air compressor that is used to drive the cabinet. I tried small ones and they just gave out. I finally went to an 80 gallon unit with a true 5 hp. motor. It puts out 21 SCFM at 90 psi and it's about the smallest I could use without having it run all of the time. Those aren't cheap anymore, either.
Good luck.
Here is a picture of my blast cabinet ad dust collector. I also use the collector for woodwork.
