Results 1 to 6 of 6
Thread: Gun distance from the part or substrate
  1. #1
    POWDERPROS is offline Platinum Member
    Join Date
    Sep 2009
    Posts
    3
    Cool Gun distance from the part or substrate
    Any opinions on holding distance of the gun tip from the part or substrate? Thanks!
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: Gun distance from the part or substrate
    Quote Originally Posted by POWDERPROS View Post
    I actually keep about 10-12 inches from the piece, unless I'm addressing a farraday issue or some other oddity. I have better results that way.
    With the HF hobby gun/s I used a lot closer measures,.... I also ran the guns at around 6 psi.... The HS, and the EW Pro,.... both work much better with larger clearance.
    EMAIL scott@scottrodspc.com
  3. #3
    Join Date
    Sep 2009
    Posts
    3
    we are using a eurotec 400d box feed.
  4. #4
    Harleydad's Avatar
    Harleydad is offline Metal Finishing Guru
    Join Date
    Dec 2006
    Posts
    833
    That's the gun I shoot, about 10 inches gun to part distance here.
  5. #5
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    about 10" for a surecoat, too. unless, like scottrods said, i'm cutting into a corner, then i'll get in pretty tight, maybe 5" or less depending on the situation and the nozzle i'm using.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  6. #6
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    There's a lot of variables (part size, shape, air pressure, humidity) but I generally shoot 10-12" with the HF guns but I run without the diffuser. With a diffuser, about 6" and sometimes 4" with lowered pressure. You're looking for complete and even coverage on that part so "one size" does NOT fit all applications. The only way to be proficient with your equipment is to practice with some parts and learn how it works with different setups. There's no set rule.
Thread Information
Users Browsing this Thread
  1. Gold Plating Automobile Badges- substrate problem
    By goldrapt in forum Electroplating Questions
    Last Post: 03-15-2009, 03:46 PM
  2. plating copper on ceramic substrate
    By kaaryans in forum Electroplating Questions
    Last Post: 06-29-2008, 07:46 AM
  3. distance between walls
    By peter61 in forum Electroplating Questions
    Last Post: 12-09-2007, 05:26 PM
  4. Distance to cathode
    By PeterM in forum Anodizing Questions
    Last Post: 10-01-2004, 01:43 AM
  5. My First PC PART!!!!
    By Noob2PC in forum Powder Coating Questions
    Last Post: 04-12-2004, 07:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
