+ Reply to Thread
Results 1 to 5 of 5
Thread: Help setting up my Nordson
  1. Help setting up my Nordson
    Hey guys, I'm hoping I can find some help here in setting up my new coating system. I've never worked with pneumatics before so I'm at a loss as to how this all goes together. Trips to the stores to look at available fittings and such have proven worthless.
    I just got a Nordson Surecoat system and, amongst other things, am clueless what I need to get to hook it up to air. It's funny, I've used a similar system in the past and know how to work it, but setting it up and setting up an air system is all foreign to me. I'm sure it's got to be an easy and obvious thing, but it's lost on me and I need to get into operation.
    Anyway the control panel itself has a push-in style tubing connector. This is where the air is supposed to hook up to. That's fine, but what type of fittings and such am I going to have to run out of my compressor so this tubing can connect into the air line? All I know about air tools is quick connect fittings and the like.
    I can provide pictures if anyone isn't sure what I'm talking about and would like to see. Thanks in advance!
    Share with Facebook
  2. Join Date
    Jul 2007
    Location
    BC, Canada
    Posts
    80
    Re: Help setting up my Nordson
    Post some pics. The surecoat has those plastic lines that go to the pickup tube and gun. The main air supply in should be on the bottom of the gun using npt and your choice of fittings.
    Share with Facebook
  3. Re: Help setting up my Nordson
    Ok you need to have a fitting that will connect off you air supply to fit the hose to you gun. If you supply hose is blue --check it to see if it is a 10mm plastic hose.You can put a plug in you pipe coming from you AC and tap it for the fitting.Also air supply to a sure coat is min 60psi -- max--100psi .make sure the air is oil free -- if not filter ,filter filter , or dryer/chiller is better.
    Hope this helps
    David
    Share with Facebook
  4. Join Date
    Nov 2005
    Posts
    945
    you probably won't find the fittings you need locally, if for no other reason than bc the nordson tubes are all metric. go onto mcmaster and find a tube compression fitting -to- pipe thread of whatever size you want. the compression fitting will have the main piece that the pipe thread is on, then a collar that screws onto the main piece, a shoulder that slides onto the tube between the collar and the main piece, and a ferrule or sleeve that slides INTO the tube to keep it from crushing when the collar is torqued. and don't over-torque it.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
    Share with Facebook
  5. Re: Help setting up my Nordson
    Thanks, I've got this figured out in the meantime. For some reason I wasn't getting my email notifications so I thought nobody had responded. Didn't mean to leave you hanging! I got familiar w/all these fittings and such and found what I needed.
    For what it's worth I've got a filter, water separator, dessicant dryer in line and then a coalescent filter off the air feed I use for the powder.
    Now onto other issues with it
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. nordson
    By RiverdaleRods in forum Powder Coating Questions
    Last Post: 02-16-2009, 11:08 AM
  2. Best place to buy Nordson?
    By rsmarco in forum Powder Coating Questions
    Last Post: 02-16-2009, 07:29 AM
  3. Setting up PID question
    By cessna182 in forum Oven Building Forum
    Last Post: 10-25-2008, 12:29 AM
  4. Help with setting up tanks
    By carts69 in forum Electroplating Questions
    Last Post: 11-26-2007, 09:20 PM
  5. Gun Voltage Setting?
    By donafams in forum Powder Coating Questions
    Last Post: 06-22-2007, 12:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
