Results 1 to 5 of 5
Thread: making powder a paint
  1. #1
    jeeplogic is offline Amateur Metal Finisher
    Join Date
    Mar 2009
    Location
    W. Michigan
    Posts
    79
    Default making powder a paint
    Here is the question.
    i have heard that you can use MEK or methy-ethyl-ketone and mix it with the powder to make a paint you can brush on. Has anyone tried this and does it work?
    If it does work what kind of viscosity am I looking for?
    any help would be great.
    Thanks
    Greg
    check out my oven building section
    www.priority1signs.com
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: making powder a paint
    Quote Originally Posted by jeeplogic View Post
    Thanks
    MEK actually evaporates too quickly to use it as a liquid paint.... using the liquid to powder products offered (at Powder buy the pound) is a better idea. You can use it in a paint gun and airbrush too.
    You can use the MEK method for touch ups in spots that you can't do much with,.... but it's not exactly the first choice for powder....
    I've also used laquer thinner to do a touch up. Either way, you should run a cure cycle for the specific powder.
    EMAIL scott@scottrodspc.com
  3. #3
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    i've airbrushed powder mixed with mek. it does evaporate too fast, though, and the dry overspray is ridiculous. i haven't heard of anyone who's had good luck with the powder-to-paint stuff. i sure didn't.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  4. #4
    moxieboy is offline Newbie
    Join Date
    Mar 2009
    Posts
    37
    I ruined a spray nozzle using the powder to liquid. Not worth the money for the stuff or I need practice. Just suspends the powder in liquid, it doesn't actually dissolve the powder so it is hard to apply or spray unless by hand.
  5. #5
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by moxieboy View Post
    yeah,... my understanding is the nozzle size needs to be a larger size than normal... and it is supposed to take a lot of practice too I figure..... Sorry to hear about the ruind nozzle.... I wouldn't have thought it to be able to do damage like that...
Thread Information
Users Browsing this Thread
  1. Powder coat over paint?
    By Deadhorse in forum Powder Coating Questions
    Last Post: 06-05-2009, 08:56 AM
  2. powder base, wet paint detail, clear powder
    By FigureLLC in forum Powder Coating Questions
    Last Post: 12-22-2007, 12:39 AM
  3. Is it paint or is it powder???
    By Harleydad in forum Powder Coating Questions
    Last Post: 12-18-2006, 07:59 PM
  4. Non-paint powder coating
    By dshepherd in forum Powder Coating Questions
    Last Post: 01-26-2004, 11:49 AM
  5. Can you use any powder paint with your
    By Toma in forum Powder Coating Questions
    Last Post: 01-04-2002, 12:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
