Eastwood and then Caswell. From what I understand Caswell sells Tiger Drylac and Eastwood sells their own...but at either rate, how crazy is this problem? I've got a friend who's a pro in the business and even he's baffled for me. It's driving me nuts since, of course, I took on a gloss black job that's got to be put on hold until I figure this out
edit: I'd also like to point out that I did indeed spend some serious time searching on this one. Not a single related subject to be found anywhere here or on Eastwood's forums. I even branched out to other PC help sites and nothing really touches on this. If such threads or pages are out there, the search terms aren't the same as what I'm using and I'm using everything obvious. Ugh!
