Results 1 to 2 of 2
Thread: Large Masking Vinyl?
  1. #1
    moxieboy is offline Newbie
    Join Date
    Mar 2009
    Posts
    37
    Default Large Masking Vinyl?
    If you have a plotter or large cutter, what do you recommend for a high temp removable vinyl that can be used for masking out large graphics on parts? I need to have some large images masked out during powder then removed during flow-out. Any recommendations on a vinyl or masking that can be bought in sheet or roll form that can Handel the oven?
  2. #2
    XaboveX112's Avatar
    XaboveX112 is offline Newbie
    Join Date
    Mar 2009
    Location
    Cicero, NY
    Posts
    45
    Default Re: Large Masking Vinyl?
    I just recently exparimented with this... I bought the 6" high temp green masking tape and stuck it to a piece of wax paper... If you set your vinyl cutter to the thickness of the tape i believe its 1mil you should be able to play around with your settings of the pressure of your cutter and cut it out... The wax paper allows you to peal the tape off then stick on your part... It will survive a full 400 Degree cure cycle with no residue.
Thread Information
Users Browsing this Thread
  1. vinyl masking
    By spankey666 in forum Anodizing Questions
    Last Post: 06-18-2009, 03:43 PM
  2. vinyl masking problem
    By smokindragon in forum Anodizing Questions
    Last Post: 02-28-2009, 11:54 AM
  3. Masking?? Vinyl Cutter??
    By hjeades in forum Powder Coating Questions
    Last Post: 09-04-2008, 06:01 PM
  4. Vinyl Masking Problem
    By PBInferno in forum Anodizing Questions
    Last Post: 08-11-2007, 11:48 PM
  5. Vinyl Masking
    By Thefool in forum Anodizing Questions
    Last Post: 09-24-2006, 08:04 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
