I have a set of cast iron cylinder heads that i want "finished." What is the best way to do this? Have them polished? Powdercoated? Plated? high heat coating? high heat paint?
I am somewhat concerned with the heat and how the finish would hold up. The car is driven about 1000 miles per year. |
I think you will fine with powdercoating the heads. I would stay away from polishing or chroming them, when you provide a smooth metal surface, you will retain heat moreso than a rougher texture. Don;t ask me why, it just does. :-> I haven't done car cylinder heads yet, but I have done Harley heads in a chrome with a clear, and they are holding up quite well. True, the engine is more exposed to cooling air, but they still run hotter than a liquid cooled engine. I believe I would give it a shot and go from there. If it does not work out, then you will know for sure. The only problem area that could be a problem would be between the exhaust ports.
| Polishing Harley Cylinder heads and jugs? | rides20 | Metal Polishing Questions | 20 | 05-18-2005 11:11 AM |
| plating trophy horse heads | Sherry | Services Offered/Wanted | 1 | 05-06-2004 04:58 AM |
| Can you powdercoat over powdercoat? | gopedhead | Powder Coating Questions | 1 | 12-14-2003 06:17 PM |
| Refinishing Metal Golf Club Heads | BillSchultz | Other Metal Finishing Questions | 0 | 08-17-2003 11:40 AM |
| Polishing aluminum chevy 350 cylinder heads | radioactive | Metal Polishing Questions | 2 | 12-04-2002 07:51 PM |
