Results 1 to 5 of 5
Thread: Powder Coating Chrome Question
  1. #1
    ProCoatSolutions is offline Platinum Member
    Join Date
    Jan 2010
    Posts
    1
    Default Powder Coating Chrome Question
    I have a exhaust set off a motorcylce that needs to be powder coated in high temp black just the end tips. Is the chrome surface a good enough surface to adhere the powder to or does it need to be stripped? Or can it be scuffed up to powder? Any suggestions would be apperciated.
    Thanks
  2. #2
    boston_jake01 is offline Amateur Metal Finisher
    Join Date
    Oct 2006
    Posts
    56
    Default Re: Powder Coating Chrome Question
    as long as the chrome is not peeling or in bad shape you can powder over it and scuffing it is fine.
  3. #3
    luv2fly is offline Newbie
    Join Date
    Feb 2010
    Location
    Auburn, IN
    Posts
    18
    What happens if it is peeling? What then?
  4. #4
    RFLIVES is offline Newbie
    Join Date
    Nov 2009
    Posts
    7
    Blast it or sand it down to bare metal the coating is only as good as the substrate it's on.
  5. #5
    Join Date
    Feb 2010
    Location
    Auburn, IN
    Posts
    18
    Quote Originally Posted by RFLIVES View Post
    Some time ago I was told on another forum that if chrome had begun peeling, etc., that for best results the nickel and copper had to be removed prior to PC otherwise the corrosion would resurface under the PC? Didn't quite make sense to me if no oxygen could penetratet the PC, the the part shold otherwise act as normal.
Thread Information
Users Browsing this Thread
  1. powder coating question...
    By robert_t_wallace in forum Oven Building Forum
    Last Post: 08-18-2009, 07:20 AM
  2. Powder coating intake question
    By ng8264723 in forum Powder Coating Questions
    Last Post: 02-21-2009, 10:08 AM
  3. Powder Coating Booth Question??
    By welterracer in forum Powder Coating Questions
    Last Post: 06-06-2008, 09:16 AM
  4. Powder Coating Question
    By ptim in forum Powder Coating Questions
    Last Post: 02-27-2007, 11:10 PM
  5. Powder Coating (Chrome) Question...
    By TCalYen in forum Powder Coating Questions
    Last Post: 05-12-2004, 11:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
