Hey Nuttyman! This forum is a great place to cut your teeth in powdercoating. It's pretty basic:
1). practice on a couple pieces of scrap metal first 2). sand blast your part(s) 3). hang from a wire and "dust" with powder (getting the right amount of powder on the part takes a little practice) 4). carefully move the part and hang in pre-heated oven to cure. Most Caswell powder cures at 400 degrees for 14-15 minutes. Other powders may vary. 5). open the oven door part way, and allow the part to cool slowly, maybe 10-15 minutes. Put one color on at a time. Put a color on the part first, cure, then cool, apply the clear, and cure again. The first coat of color will not re-melt. If you missed a spot when coating the first color, just re-coat and cure again. Mixing powder is not like mixing paint (thanks Dale! It's pretty easy, and has thousands of practical uses. The cost is so low, it's hard to find a reason *not* to powdercoat. You can figure ~ $90 for your powder gun, ~ $130 for a sand blast cabinet (Harbor Freight), a cast-off electric kitchen oven (free or dirt cheap), and a couple pounds of powder ~ $25. Don't use your wife's oven to cure powder, or your pizza will never taste the same again. Ask questions here. Good luck! Hemi-T |
Hemi-thanks for your reply. I really appreciate it! I love Harbor Freight-I just spent more money in there yesterday-there is a store about 10 minutes from my house! Is it absolutely necessary to sand blast or is heavy sanding/scuffing sufficient to give the powder a base to grab hold of?
nutty |
I've never sandpapered parts before, just sandblasted. I think sandblasting removes more oil and impurities that could cause problems in the powder. A sandblasted part is bare white metal, where sand paper leaves a lot behind. You could try it, but I don't know offhand how well it would work. Try on scrap metal first. Getting the corners, nooks & crannies would be very difficult with sandpaper. A benchtop sandblast cabinet at HF sells for $125, but you need a compressor too.
It's easy to spend a bundle of $$ on a trip to Harbor Freight Hemi-T BTW, don't buy your powder at HF. They get $9.95 for a 8 oz can ($19.90 per lb!). Caswell powder is much more reasonably priced, and comes with this cool forum to help you use it |
There are advantages both physical and cosmetic. Certain colors and textures are only available in a specific chemistry. For example if you use a Urethane color as a base and an Epoxy clear you will get a Urethane only color which has a lower hardness, and then an Epoxy which is about the hardest available. However Epoxy is not UV stable and will fade and brake down before say TGIC polyester would. Let us not forget that you can make the finish look deeper like a fine paint with the use of clear and it will also alter the shade just a bit.There are addatives that can give affects to the finish like prism powders and irredesent powders which mix nicely into the clear and then seem to be suspended above the color.
Mainly for the hobbiest it's personal preference.Usually based on appearence. Confusing yet? |
| Clear coat temp. limits | str8biker | Powder Coating Questions | 7 | 07-14-2005 10:17 PM |
| Clear coat problem | sportster883r | Powder Coating Questions | 3 | 11-21-2004 04:52 PM |
| using clear powder coat after polish? | hybred | Metal Polishing Questions | 10 | 04-03-2004 02:42 PM |
| reason for clear coat? | Jay87T | Powder Coating Questions | 14 | 03-20-2004 11:41 AM |
| Clear Coat Remover | 04sp500 | Powder Coating Questions | 0 | 08-04-2003 09:53 PM |
