Results 1 to 5 of 5
Thread: PC'n CARBON FIBER
  1. #1
    confused is offline Newbie
    Join Date
    Apr 2007
    Posts
    30
    Default PC'n CARBON FIBER
    Has anybody ever PC'd a carbon fiber bicycle. Just need to know if this can B done and if there
    is ant special prep or outgassing issues. If this can be done it will bring in quite a bit of work for me, since
    I will help sponsor a BMX racing team not to metion some free advertisement. Thanks a bunch
  2. #2
    SCOTTRODS's Avatar
    SCOTTRODS is online now Metal Finishing Guru
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: PC'n CARBON FIBER
    Quote Originally Posted by confused View Post
    Unless you know the temp capabilities, it's not recommended so much,... especially on structural stuff like a Bicycle frame.... It has been discussed numerous times on every forum I think.
    EMAIL scott@scottrodspc.com
  3. #3
    Join Date
    Apr 2007
    Posts
    30
    Thanks a bunch SCOTTRODS. That really S*^#$
  4. #4
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    i have done a piece of carbon fiber from a scrap bicycle frame just to see if it would work .
    i had good results , smooth shiny with good coverage (i coated the part at around 250 f to get the powder to stick)
    BUT i have no idea if it has weakened the fiber so i would not recommend doing a frame or other similar items unless you get the exact info on the subject from a reliable source before
  5. #5
    o1racing03 is offline Amateur Metal Finisher
    Join Date
    Jun 2008
    Location
    Dawsonville,Ga
    Posts
    89
    Like fiberglass the resins used in the making of CF will not withstand the regular curing temps of the powder.You will end up with undercured finish or a ruined bicycle and if you see what a CF bicycle frame costs you may want to steer clear of this job. There are some very low temp powders out there that could be used, but I have found they dont flow as nicely as a higher cure temp powder. So its coat, cure, sand, coat, cure, sand, clear. By the time you're done your $75 coating job ends up being $200-$300. Maybe worth it to someone who can afford a CF frame.
Thread Information
Users Browsing this Thread
  1. Carbon bicyle frame
    By peter61 in forum Powder Coating Questions
    Last Post: 09-10-2009, 12:25 AM
  2. powder coating carbon fiber
    By dagall in forum Powder Coating Questions
    Last Post: 09-23-2008, 04:26 PM
  3. Carbon Fiber looking powder?
    By Deecoat in forum Powder Coating Questions
    Last Post: 04-19-2008, 08:44 AM
  4. Stainless to look like carbon?
    By snoopygolf in forum Other Metal Finishing Questions
    Last Post: 06-12-2006, 11:52 PM
  5. carbon fiber
    By hulk30 in forum Caswell Please Sell This...
    Last Post: 04-20-2006, 09:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
