Sorry to hear about your troubles! I know what you mean as we see that happen in our facility every so often.
I would suggest a couple options: One, you can manually remove what the media blasters missed. You could use a knife, scraper, or some other tool to remove any left over coating. That may be difficult but worth it if you can expose the underlying metal.
Another option that has proven successful for me in the past is to lower your kv down really low and/or pull your gun farther from the part and you may see that the powder will cover even over the areas that have leftover coatings.
Let us know if you find a good solution.
Marshall
LinkBack URL
About LinkBacks
