Welcome to the forums Schaffer.... You can do a couple of things that would be considered blending,..... one would be blending tow dry powders together, and then shooting them,.... they MUST BE THE SAME CHEMISTRY AND CURE PARAMATER powders to do this..... Another way to blend, would be to blend two powders together in a "FADE".... this doesn't require the absolute match of chemistry if you use the right technique,.... but if you shoot both colors dry (or however many colors you shoot),....they should be the same chemistry. If you shoot one color, thenm cure,... then shoot the second or subsequent coats, each after full cure,... you can do different chemistry powders over one another.... Clear as mud?
LinkBack URL
About LinkBacks
