all depends on blasting time to get down to the pitting will most likly take a lot of blasting and a few coats of kl to fill all the pitting. depending on your setup will set the cost. when I was working from home it was easy I fidgured out how much time it would take me to get the parts completed and add up materials used including electric gas media and such say its 50 worth of power powder media and it takes you 5 hours to do the parts even at 10 bucks a hour your still looking at 100 bucks. personaly even when I was out the garage I woundt work for less then 20 to 40 a hour. also rember the going rate for 2nd coats is 50% added to the cost and if you shot primer chrome and a clear your looking at a lot of just oven time to get to temp and hold it.
Josh
LinkBack URL
About LinkBacks
