Results 1 to 5 of 5
Thread: Spot filler to use before powdercoating
  1. #1
    jitglobal is offline Platinum Member
    Join Date
    Sep 2010
    Posts
    2
    Default Spot filler to use before powdercoating
    We powdercoat various steel plates and other objects and are looking for a filler that can be used to fill scratches and gouges up to maybe 1/8th deep (most much less) before we apply our coating.
    What are some of the options out there?
    Thank you all in advance
  2. #2
    missile150 is offline Amateur Metal Finisher
    Join Date
    Aug 2010
    Location
    Wichita, KS
    Posts
    61
    Default Re: Spot filler to use before powdercoating
    I have used Lab Metal for some of my stuff. Seems to work fine. I did not use the high temp stuff, as I only cooked the parts once, and the thinner they sell is nothing more than a 50/50 mix of acetone and toluene paint thinner, so save some money and pick some up to mix in a small batch instead of the Lab Metal brand thinner. It also goes on easier when it is thinned a little. But it can set up fast, so be careful and purposeful in your usage and amount.
  3. #3
    Join Date
    Sep 2010
    Posts
    2
    Has anyone tried Thermobond 3?
    Thanks for the reply.
  4. #4
    magna750 is offline Newbie
    Join Date
    May 2009
    Location
    Sodus Point, New York
    Posts
    16
    We use Lab metal for the big stuff and liquid metal from NAPA or any auto store for small scratches and gouges without any problem. We always bake the liquid metal above the powder cure temp before sanding and coating
    Ultimate Finishers, Inc.
    235 Murray Street
    Newark, N.Y. 14513
    585-289-3053
    www.ultimatefinishersinc.com
    Facebook
  5. #5
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    You can use Quicksteel Putty, or JB Weld also. These two are great as long as you're not shooting a heavy metallic flake powder. The flakes stand differently over the filled spots. I suspect that could happen over any of them if the filler is too thick too.
    EMAIL scott@scottrodspc.com
Thread Information
Users Browsing this Thread
  1. bad mat spot with gloss paint
    By mballard34 in forum Powder Coating Questions
    Last Post: 06-29-2010, 10:49 PM
  2. Spot Welder
    By Dusty in forum Anodizing Questions
    Last Post: 06-12-2007, 08:46 PM
  3. Anodizing after spot welding
    By whistule in forum Anodizing Questions
    Last Post: 12-01-2006, 09:32 PM
  4. Possible to recoat a very small spot?
    By Deecoat in forum Powder Coating Questions
    Last Post: 09-10-2006, 09:39 PM
  5. Spot repair hard anodizing?
    By remotestartdepot in forum Anodizing Questions
    Last Post: 01-30-2005, 12:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
