FREE POWDER COATING SYSTEM
hey i cant find a oven and if i do they are too expencive. So i think im gonna go with a lamp. Would a 1500 watt lamp be good? i would do r/c parts and i want to see if it would be good. I have a question about them too, if i would buy 1 lamp wont i need 2 for one on each side? If not then how would i do it with 1 lamp?
assuming you're not trying to coat a park bench, lol....that lamp should be fine for little RC car parts and what not. You'd be surprised how hot a focused 1500 IR lamp can get. It heats what it sees,basically (ergo....don't put your hand in front of them too long or you'll be surprised right quick). When one side of your part is almost cured, rotate it 180 degrees and bake the other side. Assuming that's a flat piece, mind you. OR...one can be very inventive and find an old record player, hang upside down and find some way to make an inverted turntable/carouself to hang the parts from? I dunno....never tried that one to be honest. But then again.....necessity IS the mother of invention,yes? As long as it's a low/no buck trial...I say do it all and stop at what works best for your applications. Of course..... come back and post the results for all to share, no matter how unkosher they may be. Good luck.....Russ
k i will try it, my birthday is on october 31st so im gonna get a powder coating kit then and with the money i get i will get the lamp and all of the other stuff. I already have 2 very powerful air compressors i just need a and blasting cabinet and i will be set. Thanks for your help. I dont feel like spending like 500 dollers on a oven when im only doing R/C parts lol
I'm with Hemi on this one,bud.....explore all opportunities with a standard oven first. Maybe salvation Army? I dunno. The IR lamp will definately work for you in the manner which I said....but you can always graduate to that later if your needs expand. Remember folks....while they may not always be the best, no buck/low buck solutions are always a good place to start. After all.....if it doesn't work, what did it really cost you but valuable learned experience
Hi guys,
I purchased a curetek 1500 watt lamp about 9 months ago and have yet to get the thing to cure powder Am I doing something wrong or can this thing not cure powder? Please let me know if anyone has some suggestions! Sincerely, Paul |
I'm kinda curious about this myself as to what happened. Workable distance from part to lamp should be about 12-14 inches (depending upon what lamp you ordered and what substrate you were trying to coat). Also.... how did you know it reached what temperature it did? Curious about that as well. Sounds like maybe one of the bulbs was out? I dunno.... just odd to not have it do what it's supposed to do is all. Let us know what's up please.
I just got the M-1500 cure lamp from caswell and tryed it last night. i used the flat black powder then put the lamp on it and it just flowed out the powder but didn't cure it. i left the lamp on it up to 15-20min at 8-10'' away from part and still didn't work. i had to put my part in the oven to cure it. did i do anything wrong. I will try agin later and see if i can get it to work.
WARCHILD |
| 1500 w lamp | suprtong | Powder Coating Questions | 1 | 03-12-2005 06:50 PM |
| Ir Lamp somebody help me!!! | Sezer | Powder Coating Questions | 4 | 06-10-2004 11:33 PM |
| polishing a brass lamp | artp | Metal Polishing Questions | 2 | 02-02-2004 11:13 AM |
| lamp heat | duke | Powder Coating Questions | 13 | 01-06-2004 12:44 PM |
| Lamp Reflector plating | Marcos | Electroplating Questions | 1 | 02-15-2003 01:37 PM |
