Results 1 to 3 of 3
Thread: Anodize vs. Powder Coat
  1. #1
    cpowellpumphrey is offline Amateur Metal Finisher
    Join Date
    Aug 2010
    Location
    Gulf Coast near Houston
    Posts
    73
    Default Anodize vs. Powder Coat
    My wife is making wind chimes. She wants me to anodize and dye aluminum tubes so they will be colored. I am thinking that perhaps powder coating would be a better deal since there are more colors available, or so it seems. To cut to the chase here are my questions.
    1. Which method is better for outdoor aluminum coating? I want the process to be free from sun fading.
    2. Powder Coating seems to have a wider color availability. Do you agree?
    3. The start up costs seem to be about the same or am I mistaken? Power supply vs compressor; guns and stuff vs tanks, tubes, buckets and tubs.
    4. I have seen Powder Coated wind chimes but they are always in flat black. Any particular reason that you're aware of?
    5. The learning curve seems to be about the same. Meaning that they both will take about the same amount of time to learn to do right. Do you agree?
    6. Does powder coating change the tone of aluminum tubing? From what I have seen it doesn't seem to. I know anodizing does not change the tone which is the important thing. The flat black chimes I have seen sound like just fine.
    Any help you experienced guys could provide would be much appreciated.
  2. #2
    Join Date
    Aug 2010
    Location
    Posts
    73
    Default Re: Anodize vs. Powder Coat
    I guess I ought to add that if this works out it will be my retirement job starting next year.
  3. #3
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by cpowellpumphrey View Post
    Powder will indeed have an affect on the tone,.... it adds mass, and screws with Cymbals too..... If the tubes are cut AFTER coating, the tone will be adjustable to the new density and mass change. Anodized WILL NOT have any adverse tone issues.
    The tone issues may be negligible but they will exist with PC.
    I haven't a clue what the costs are on the anodizing set-up and operation, but the cost of starting up powder coating can be all over the place, depending on the level of perfection you seek. You can go as cheap as a couple of hundred dollars or as much as several tens of thousands.... The volume and type of powder coating can have a say in how much the start up costs are also.
    EMAIL scott@scottrodspc.com
Thread Information
Users Browsing this Thread
  1. Powder Coat Primer with Wet Paint Top Coat?
    By FigureLLC in forum Powder Coating Questions
    Last Post: 07-02-2008, 08:25 AM
  2. Anodize or Powder Coat?
    By Grumple in forum Anodizing Questions
    Last Post: 05-15-2008, 05:51 PM
  3. Powder over anodize
    By UrineMachine in forum Powder Coating Questions
    Last Post: 11-14-2007, 07:56 PM
  4. Newbie: Powder Vs Anodize
    By ianking in forum Anodizing Questions
    Last Post: 12-23-2006, 12:23 AM
  5. Combined powder coat & anodize
    By seanc in forum Powder Coating Questions
    Last Post: 09-03-2004, 12:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
