well....let's start off with what you can't do as that seems to be easier to solve in a powder coating application. One cannot "mix" powders as you would with a liquid pant. For example.... Yellow and blue paint mixed makes green basically,right? Yellow and blue bowder mixed will give you yellow and blue speckled powder. NOT a pretty sight. All of the mixing is done for you guys at the formulator stage. You order gree, you get green. You order yellow, you get yellow. Never the twain shall mix, so they say. There is one exception to the rule as far as most of you guys are concerened,though. There's a product out on the market that adds a prismatic effect to clear or tinted clear coats. A little advanced for you guys as of yet, but we'll touch on that in future posts,k? (I promise). It's basically a "metallic" for lack of a better term.
As far as the parts that you wish to coat. I think you'll find you are in good company here. I've seen pictures of all sorts of things here at various sizes with much success. Rims and bike frames are well within the hobbyists realm of possibility. As for the "big oven"...yes, that information on how to build one can be had around here. May I suggest something first though? Seeing as how you are new to this hobby, why not pick up a cheap (at a tag-sale,Salvation army, relative throwing one away perhaps) electric oven and experiment with that for a little while. Get the "feel" for the process as it were. Do a lot of small parts before you go putting an expensive motorcycle frame in there and don't know what you are going to get. I'll say this right off the bat....and ANYBODY here feel free to tell me I'm wrong....once you get something powder-coated, it's a royal pain in the you know what to get it off once it's baked and cured. Especially something with as many corners and tight spots as a bike frame. Ease into it before you go into the "advanced hobbyist" stage of things. Sage advice from somebody who's messed up and learned the hard way for a great many years. Once you have played with the system a bit, come back and we'll talk about the oven-expansion. You have many sources here who are quite good at the areas you will be moving into, much less more than friendly enough to help you (one couldn't ask for a better group of like-minded people in my book). Just better to crawl before you can walk is all I'm saying.
Aside from that....welcome to the world of powder coatings. Buy the system here, some powder and invest in a cheap electric oven. Take your time and come back to look at out posts for tips and tricks. But most of all.......have fun with it! Hope that helps....Russ
