Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 10-23-2003, 11:44 PM
duke
Default sand blasting cabinet...relocated to tips n tricks section
hi guys,
found this tip that helped me,so i hope it can help some of you to rig up your own cabinet. i will be making mine out of ply, thanks to help from tomg502001 & nonstick
The blast cabinet is simple, you’ll need the following:
1) a large cardbord box (about the size a 27” T.V. would come in) - Free
2) a siphon sand blasting kit (gun, hose, nozzle etc...). PROD CY7003 Sandblast Kit $19.95
3) a large coffee can - Free
4) an old pair of pants - Free
5) a pair of x-large platex gloves - $2
6) a small piece of plexiglass (approx 5” x 10”) - hardware store.
7) a garage trouble light
a small shop vacuum or an old sock
9) a bag of play sand $2.50
10) some tie-wraps
11) a roll of duct tape - every garage mechanic has some.
Okay, here’s what you do.
1) With the box sitting so that the top opens upward, locate the largest side and cut
two arm holes in it about 4 to 6 inches above the bottom. The arm holes should be
about 4 to 6 inches in diameter.
2) Cut a square hole in the box for the plexiglass window. The hole should be slightly
smaller than your piece of plexiglass.
3) On the right or left side, cut a hole just big enough to insert the line from your
compressed air source. The hole should be positioned about 3 inches from the bottom
and towards the front. (This is hole “A”)
4) On the same side as #3 make a small hole about 2 inches from the top and
towards the back of the box. (This is hole “B”)
5) On the opposite side from step #3, cut a 3 inch diameter hole about 2 inches from
the top and 2 inches from the back of the box (This is hole “C”)
6) Cut the legs off the pants & put them on your arms. Then put on the platex gloves.
7) Have a friend tape the end of the pant legs to the wrist of the gloves. Apply the
tape as loose as possible.
Put your arms in the arm holes of the box and have your friend tape the top of
the pant leg to the outside of the box around the hole. Remove your arms from
the gloves and arm holes.
9) Tape the open end of the sock around hole “C” or insert the nozzle of the shop
vacuum here.
10) Open the top of the box and tape the plexiglass around the square hole.
11) Put the plug of the trouble light through hole “B” from the inside and mount the
light to the inside of the box. I used tie-wraps. Note: do not use anything over a
40 watt bulb for safety reasons. DO NOT leave the light on when you are not blasting
12) Fill the can with dry sand, and insert the siphon part of the blaster. Put the can
in the box and run the air supply line in through hole”A”. Make the connection to
the blasting gun, place the item you want to blast inside and close the box.
13) Seal holes “A” and “B” with duct tape
14) Start out with about 40 pounds of pressure for your first try then adjust the
pressure to your needs later. DO NOT aim the blaster at the light source. Best to
use outdoors and away from admirers. Wear goggles for an extra margin of safety.
hope this helps someone in this great forum.
regards DUKE.
Old 10-24-2003, 12:05 AM
tomg552001
Send a message via AIM to tomg552001
Duke, i'm glad you're making one out of ply. Sorry i havnt gotten you pictures yet, it keeps escaping my mind. I just wrote myself a note, so i'll snap some tomorrow and send them your way. Thumbs up to being crafty.
Old 10-24-2003, 12:11 AM
Hemi-T's Avatar
Hemi-T
I made a cardboard box blast cabinet to do the rear axle housing for my street rod. They don't last, but will work for specific jobs. I lined the entire interior of the box with duct tape. This helps it last longer. Spring $5 for a bag of Black Magnum blasting grit instead of play sand, though. You're kind of splitting hairs (expense wise) on that one.
Hemi-T
Old 10-24-2003, 12:23 AM
tomg552001
I love my wood cabinets. Much easiar to make than metal, especially for those of you who don't do metal fabrication but have wood working tools(most of us have atleast a circular saw), much cheaper than buying one that large, much cheaper than buying sheet metal and they work just as well . I dont think i'll be trying the cardboard box one though, haha.
Old 10-24-2003, 12:24 PM
non-stick
another sterling set of ideas,Duke. Gotta love them low-buck/no-buck solutions to problems. Just shows what one can do when they get a spark of creation and add flavor to it all. Thanks for the post,bud......Russ
Old 01-14-2005, 11:23 AM
wolfpline
Default Blast Cabinet
Just an idea; since a blasting cabinet is best if sealed and the media is in a close-loop system, why not just get a chest Freezer. They are in the paper FREE all the time if you and a friend go move it. Once at home knock 2 or 4 glove holes in it, a nice long viewing window, air attachments, and some tension clasp locks to hold the top shut and your done? Right? Parts load in from the top. You could even make a rack to hold them off the bottom and put in a trap door for abrasive removal. Then if you want to get real industrious, find an ATV lift in the classifieds ($30-$50) and you can raise and lower the thing with an air to load heavier parts into it. Even from an ergonomics standpoint you can custom adjust the height to anyone using the cabinet. No more stooping to see in resulting in a sore back. Any thoughts?
Old 01-14-2005, 07:43 PM
customandsound
Guest
Posts: n/a
play sand is not good for your health
  #8 (permalink)
Old 01-23-2005, 09:36 PM
11111111's Avatar
11111111
Send a message via MSN to 11111111 Send a message via Yahoo to 11111111
if i didnt already have a big walk in blast cabinent i would use a freezer. never thought of it before but a very good box to convert. good idea
Thier are only two real sports!
boxing and auto racing
all the rest are just games.
Drive it like you stole it!
  #9 (permalink)
Old 06-11-2006, 06:41 PM
Default Re: sand blasting cabinet...relocated to tips n tricks section
man, that's a familliar looking avatar. You wouldn't happen to be B-man from TAC/PY Forums would you?? If so, It's Zippy here.
  #10 (permalink)
Old 11-13-2007, 05:54 AM
tr4dude's Avatar
tr4dude is on a distinguished road
Smile Re: sand blasting cabinet...relocated to tips n tricks section
if you have the time and a wire welder i made me cabinent out of a used wide 2 drawer filing cabinent that i picked up for free, i cut out the bottom and used the metal from the drawers to make the feed for the siphon, i used 2-- 4 inch pvc toilet flanges $8 that screwed into the front and hose clamped the $3 gloves on the inside. used the drawers to make the side door and a $10 piece of plexiglass for the front, cut a hole and bolted a piece of my shopvac hose to the side, i used 2x3's for the frame to set it on--free wood, got a $8 flourescent light from biglots, and a piece of expanded sheetmetal for the floor-- $12, it was cheap, came out good, works good and got to practice my welding at the same time.
Closed Thread
Tips and Tricks non-stick Powder Coating Questions 30 10-02-2009 08:33 AM
20 Silvachrome tips and tricks polygon Other Metal Finishing Questions 4 06-02-2003 09:29 PM
