Old 11-10-2003, 06:27 PM
dsacco1013
Default outgassing?????
Can I preheat items with a torch to prevent outgassing?
Dave
Old 11-10-2003, 07:27 PM
non-stick
noooooooooo. lol. Torch is too much heat focused in one area too long. Best to pre-heat in an oven as described in Tips and Tricks and be safe about it that way. The air pockets in non-ferrous (aluminum in this case) don't take kindly to rapid expansion. It may just crack on you.....Russ
Old 11-10-2003, 08:52 PM
dsacco1013
That would be on large items,(the hey I cant put THAT in an oven) and I wouldnt hold it there for extended peroids of time. You know move it around a bit evenly....no
Old 11-10-2003, 09:17 PM
non-stick
ummmmmm. no,lol. Seriously though... if you wanna risk it, be my guest. I suppose anything is possible in this world but how were you going to cure the powder anyways? Just pre-heat via that method. Maybe if you told me what you are doing or more specifically....what you were trying to coat and what sources for heat you'd have available to you, I could help a little more. Generally speaking...you'd have to have a painfully light touch with any torch to cast aluminum though. One crack or fissure and that part is history.... big or little.
*edited* I'd also tend to think that with heating like that, you'd be putting some quick oxidation on the part as well,no? Just a random thought.
Old 11-11-2003, 02:31 PM
tomg552001
Send a message via AIM to tomg552001
Yea, i wouldnt use a torch....just preheat it the same way you'd cure it. Putting a torch to cast aluminum will most likely create some carbon build up or some kinda crust that would screw up adhesion....maybe? *shrug*
Tips and Tricks non-stick Powder Coating Questions 27 11-11-2007 02:01 PM
Outgassing? How long estevahn Powder Coating Questions 2 06-10-2005 10:32 PM
*&%$@ Outgassing! KZjim Powder Coating Questions 10 03-13-2005 04:40 AM
Powder coating a 57 chevy dash cluster Coast2CoastPC Powder Coating Questions 5 01-05-2004 09:25 PM
