Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By SCOTTRODS
Thread: Powder coating new rims
  1. #1
    mandem615 is offline New User
    Join Date
    Jan 2012
    Posts
    5
    Default Powder coating new rims
    I have a set of rims I want to powder coat, they're off a 2010 camaro and have no scratches or anything wrong with them. Would it be okay to primer the rims then powder coat them instead of stripping the factory coating off the rims. I seen someone do it in a youtube video. If its okay what primer should I use. Any responses would be greatly appreciated.
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: Powder coating new rims
    Quote Originally Posted by mandem615 View Post
    Yeah,... I saw the guy in Houston do the wheels with no real prep.... don't take your wheels to them.... He has no idea how well that will hold up over the long term. Probably even blame the original coating if anything goes wrong, instead of taking responsibility for his **** poor prep.
    Do not do them that way, as the factory coatings are done under some VERY tight environmental specs, and you cannot do that at home. (or in a small custom coating shop). Always treat the parts (wheels in this case) as though they are new, fresh parts, that need complete prep. Strip them first, Blast them completely, Pre-treat if you do that, Coat and cure. No shortcuts is basically the rule here.
    Jycorro likes this.
    EMAIL scott@scottrodspc.com
Thread Information
Users Browsing this Thread
  1. Powder coating Aluminum rims
    By rr83sporty in forum Powder Coating Questions
    Last Post: 06-22-2008, 07:32 PM
  2. Motorcycle Rims Need Powder Coating
    By Lt_Dan in forum Powder Coating Questions
    Last Post: 04-17-2007, 05:17 PM
  3. Powder coating rims
    By precise in forum Powder Coating Questions
    Last Post: 12-15-2006, 08:16 PM
  4. powder coating Rims
    Last Post: 11-30-2006, 01:37 AM
  5. Powder coating rims
    By Crimson in forum Powder Coating Questions
    Last Post: 11-04-2005, 03:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
