Traditionally compressors are botled either to a skid for maneuverability or for sake of absorbing vibration. You can also pound some 3/8 X 3" concrete lags through the available holes into the floor, but put a block of rubber down sandwiched inbetween the two. Standing on concrete for hours is bad enough without all the vibration going to your feet
it's got a good hum to it, lol... that's for sure. After a while I guess you get used to it and it just becomes one of those acceptable background noises. This is why I always suggest rotary screw type compressors as opposes to piston type. A little more expensive but the added bonuses are sooooo worth it. Quieter, quicker reclaim on lost air pressure, ease of maintenance,etc. Of course... they cost a wee bit more. There's no major difference between 115V and 220V as far as sounds goes, I believe. Noise is noise, so they say. Perhaps a decibel here or there, but you'll not notice the variance.
If you get a quality brand compressor, chances are it will be a lower rpm motor....between 1250-1725 rpm or so....this will actually be a bit quieter than a 110 compressor which usually run at a real high rpm to make up for its lack of power. The lower the rpm, the longer the life and quieter it is
thanks 11111111
i had thought of a gas unit, i guess you would have to have it outside as the noise would deafen you, or is there some way to suppress the noise? & then there's the neighbours to worry about if you can't quieten it down,the mobility aspect has my interest though. are you diving abs, or do you do salvage work? |
