thanks for your input jeff,
i am locating compressor only temporary in garage untill i build work shed. compressor is rated at 15 amps, what i intend doing is, make up lead to plug in to dryer outlet which is on 30 amp circuit. this will make life much easier for me.do you think this will work o.k? if you agree, what gauge wire would you advise i use? i will copy your last post for use when i finally move compressor lowes has 60 gallon c/h for $399 with 12 months interest free cheers |
I have a 25ft cord on my 220v compressor. It's a *very* heavy gauge cord. Having enough copper to handle the load you're drawing is all you need to worry about. Voltage drop due to insufficient cable size will wreak havoc on your compressor motor.
Hemi-T |
You should be just fine, It is a lot cheaper to make a cord from a roll of the nomex than to buy it as a extennsion cord. and then you can use it in a permanent installation when you get to it and you dont spend any extra cash.
Thier are only two real sports! boxing and auto racing all the rest are just games. Drive it like you stole it! |
