I don't think they would...but if you search on line i bet you can find one easily. I'd also try ebay, if you use that.....just make sure you get one you can step on and it stays in the open position....you could always put a ball valve on the outside of the cabinet in the air supply aswell....that way you can turn it on or off if you cant find a foot pedal. Good luck!
Yep, whatever works....they do make a pedal that once stepped on stays open keeping the air flow open, and once you press it back it shuts it of. BUT, why buy an exspensive pedal when a ball valve is $3.00 at home depot
| sand blasting cabinet...relocated to tips n tricks section | duke | Powder Coating Questions | 15 | 12-30-2007 12:28 PM |
| Sand Blasting Q? | cypress_33415 | Other Metal Finishing Questions | 3 | 12-26-2005 09:08 PM |
| Type III (hard coating)? | xtal01 | Anodizing Questions | 5 | 01-12-2005 12:05 AM |
| Looking for a MASKING product for blasting ops | Halliwell1 | Other Metal Finishing Questions | 3 | 04-21-2004 08:23 PM |
| WHICH BLASTING MATERIAL SHOULD YOU USE FOR THE 1ST TIME | BRANDONPEAKE | Powder Coating Questions | 4 | 01-10-2004 01:30 PM |
