Old 11-26-2003, 04:14 PM
dsacco1013
Default how much voltage?
When useing the "Hobbist" gun, should you measure the voltage with a voltmeter? And if so should you set it on a AC volt setting or does the box change it to a DC current?
Thanks Dave
Old 11-26-2003, 04:29 PM
non-stick
wow... good question, Dave. I have no clue about the hobbyist gun settings to be totally honest with you. I may be speaking out of line here (somebody correct me if I'm wrong please) but the hobbyist guns are preset at 20KV, aren't they? As for what type of voltage you have.... it's DC current. Basically it's an elaborate system to transform 120 VAC to 20,000 VDC. The industrial guns are no different. Amperage is nil so you don't have to worry about that but, industrial goes up to an adjustable 100KV (one hundred thousand) VDC. I'm betting if your gun is active, the setting is where it should be regardless..... Russ
Old 11-26-2003, 05:53 PM
tomg552001
Send a message via AIM to tomg552001
Thats correct, hobby guns are a preset KV :P
Old 11-26-2003, 06:19 PM
dsacco1013
That would explain why I wasnt getting a reading on the AC side of the meter, and I did not try DC. But I wasnt complaining because the powder was "Sticking"....Why ask how kinda thing.
Thanks
CopyCad & Zinc failure - electrolyte problems? seanc Electroplating Questions 4 11-08-2004 09:16 AM
Voltage movement PeterM Anodizing Questions 2 10-13-2004 04:47 AM
Titanium Anodizing ron423 Anodizing Questions 4 08-23-2004 04:09 PM
Peak voltage question mudwhump Anodizing Questions 6 01-14-2004 10:53 PM
