Old 12-02-2003, 08:45 PM
dsacco1013
Default Powder Coating chipping?
Am I not getting good adhesion or is that the nature of the beast? I am spraying it, it might be on there a bit heavy but after it cures it looks so good. I thought maybe it wasnt curing good enough because the IR light will only get the part to 300. It does flow out drys nice and looks great the only thing is that it does chip fairly easy.
Dave
Old 12-02-2003, 09:18 PM
Hemi-T's Avatar
Hemi-T
How did you prep the part? It may be that your chipping problem is caused by poor adhesion from improper surface prep. I sandblast, apply powder, and cure. Powder coating is known for it's resistance to chipping.
Hemi-T
Old 12-02-2003, 09:25 PM
drfjr1976
I was going to say the same thing Hemi-T It could also be that it is not completly cured. I would check to make sure the part was properly preped first.
Old 12-02-2003, 09:35 PM
dsacco1013
That is what I thought. The first piece was a piece of one inch square tubing bare I just wiped it down with thinner. That turned out alright 1 to 10- 10 being good it was a 7. Second piece was a bracket bare metal, I sanded down with 220 that was about a 6. Third piece is a receiver hitch pin bare sanded and wiped with thinner, adhesion a 4 looks an 11. 7...6...4...See where thats going don't you! Thanks HemiT for backing up what I thought about the "Hammer tough" coating. I am going to try to sand blast something tomorrow.
tomg552001
Send a message via AIM to tomg552001
Yep, its under cure, or improper prep.
Old 12-02-2003, 09:37 PM
dsacco1013
drfjr1976 if the IR light wont get the part to 400 for 14min ...will say 275-300 for 20 min do the same thing?
Old 12-02-2003, 09:40 PM
tomg552001
If the temp of the lamp won't go higher than 300, cure much longer. Depending on what you're curing, i'd go for a good 35-45 minutes or so. Or maybe 25-35 once it starts flowing. Better safe than sorry, and its hard to over cure powder at that temp.
  #8 (permalink)
Old 12-02-2003, 09:44 PM
dsacco1013
Ok here is the plan.....Tomorrow
1st find a part
2nd sandblast it
3rd wipe with thinner
4th cure 35 minutes on each side
Can I over cure?
Thanks guys.
  #9 (permalink)
Old 12-02-2003, 09:47 PM
tomg552001
From what Russ says, you can not....unless you cure it in a burn off oven maybe . Your plan sounds good....you may even want to go longer if you're coating a dense, thick part.
  #10 (permalink)
Old 12-02-2003, 09:52 PM
dsacco1013
Sounds good guys. I will update yez guys later. (It's a pittsburgh thing)
*** WE ARE GIVING AWAY FREE POWDER COATING *** mcaswell Powder Coating Questions 197 07-08-2008 12:31 PM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 08:15 AM
Powder coating on firearms LoneGunman Powder Coating Questions 2 06-15-2006 12:54 PM
Non-paint powder coating dshepherd Powder Coating Questions 6 01-26-2004 11:49 AM
Powder coating process.. tomg552001 Powder Coating Questions 4 01-14-2003 07:42 PM
