I’ve read through an awful lot of the posts on the website and my question looks to be one that I haven’t seen addressed yet. It “may” be better suited for another forum, but I was hoping to get some advice.
(Generic information) I would like to make customer powder coated computer cases facades. For the sake of simplicity, let’s use just the front piece. It will basically be a 10” x 18” x 1” tray. (Problem) I live in an apartment; I have a detached garage (WAY too far for an extension cord). In my garage, I have a single light bulb (presently running 100W bulb) and I have a single 110 outlet (presently my garage door opener, and whatever else I have plugged in at the moment.) I know from experience that I can run a miter saw, drill press, (small) ceramic heater, or halogen lights at the same time… however… I see some dimming of the main overhead light when they are turned on. So the question is this…how can I cure in my garage without popping a breaker and killing power for all the garages (all of which have electric openers…which would generally be considered a problem)? First thought was a toaster oven, however, desired size seems to exclude. Next I thought about picking up a used 110 oven, but I have NO idea how much power they draw or even if I have enough juice to run them. I am playing with the idea of the Prod M1500 for $188.50 but that is only because I am guestamating that is approx equal to the load from the miter saw or the halogen light. I’ve seen propane based curing systems on another site, but I keep reading that you CAN use an awful lot of things to cure, you just compromise safety. Personally, I have no desire to experience a small explosion in a garage. (Or GASP… do I need to relegate myself to the idea that I will need to find someone else to PC for me for a few years until I own a home.) Thank you for any advice or input you can provide. Scott G |
Welcome to "da boards", skot. Quite an interesting dilemma you have there. I don't know if it's possible, but can you just change the circuit breaker that goes out to the garage? That's meaning to say.... if there's currently a 15-Amp breaker on there now, will the landlord let you install a 20 amp? Is there enough amperage in the panel itself to allow yet another breaker installed and you running a new line out there? You never mentioned if it was a complex you live in, or just a multi-family. Also.... what kind of person/people is your landlord. If you told him straight out "listen.... I want to use the garage (a structure that I'm paying rent on and should be able to use) for a hobby of mine and I need some power, it's non-toxic and safe and makes relatively little noise... can we do something about getting a little power out there"... would he help you with it, or at the very least not mind? If he's hooked up to the internet, SHOW him what you've found so that he feels at least a little bit re-assured his investment won't be blown to bits,lol. Perhaps he/she may like it and want to do it as well... therefore making your situation easier to deal with. Who knows, maybe your landlord may even have things for you to work on (heat registers, hinges, etc) and that would make it easier to get what you want out of this situation? I dunno..... it's a question of power, per se. In your instance.... if you are NOT able to have an oven, the IR lamp is your basic next logical step. You just basically have to do and find out a few things in order to advance, in my opinion....
1) Tell your landlord what yo are doing. Don't do anything on the sly. They hate tyhat and it's only fair because it's not dangerous and they might find it useful for themselves as well (leaving it easier for you to bargain out some power). 2) Is the electrical panel suited for some more power useage? Sometimes in an older structure 100A service is in place and quite a bit of the resources are already spoken for. 3) Is a 15A circuit breaker in the place of the garage line? You can switch it over to a 20A and end a few tripping issues, I'd think. 4) Is there room for another circuit breaker in the panel to run another line to the garage? Tell the landlord you'll do it at your expense (they love that sorta thing and romex and breakers are cheap). If all of the above looks good, it's a viable way to go. Answer the above questions to yourself (and here if you don't mind) and I have no doubt we'll be narrowing down the best direction you can take. I have no doubt your'll be able to powder coat. It may be difficult and you might have to make a few exceptions (turn this off while using that) but it doesn't sound impossible..... Russ |
I really haven’t made any movement in one way or another. The actual property manager is on vacation and will not be back for a few days. They have people who are working in the leasing office, but no real decision power. (Not to mention the fact that it is unseasonably cold in Seattle right now, and the garage is VERY VERY cold.)
In answers to your initial questions: Quote:
Which comes back to the primary question…how to cure if you only have access to minimal power. At this point, I am really contemplating options like just making smaller metal items and cure in a toaster oven to see if I actually enjoy powder coating as much as I think I will. Also figuring that this will give time to learn the craft and become more proficient at applying coatings. Scott |
it really is quite the conundrum you have going on there, Skot. One needs electricity and compressed air to powder coat, plain and simple. How to do that in a structure where you are limited to both, I do not know. You may indeed have to use only one device at a time until you figure out the best way to do things. Can you rob power from somebody elses' side?
Hmm, this sounds like my dilemma. I too live in an apartment with a very far detached garage. I do know however that mine have a 20 amp breaker but it sounds like they may be of the GFI variety as my neighbors 6hp compressor trips it even though it's supposed to only draw 12 amps.
If there's something else on when you get the compressor started up, then it will trip. Hook a meter up and you'll see the amperage spike up way past the 12 amps on start-up. All motors do this. It's not unusual to see a spike of 22 for a fraction of a second and this may be the reason it keeps tripping. If it doesn't happen on start-up, it'll happen when the compressor cycles each time when deamnding air for the tank. Sooner or later, it's gonna get ya on one of them. Also... the harder that motor works and pressure builds, the more amperage you draw. If the motor is on it's way out it will trip the breaker as well. Check your pressure sensors and the like to see if they are clogged or need to be replaced. You'd be surprised how many problems a non-functioning piece can effect something somewhere else.
I totally agree with Dale. Make sure that breaker isn't weak and has a natural "want" to shut off because it's been tripped too many times. You'd be surprised what a difference that makes. Yet more words to live by Dale... Thank you.
