Hey guys,
Here are a couple of pics of my set up. I have my spray booth on top of a cabinet that is on wheels so it is easy to move around. I made the spray booth out of wood and then drilled 4 holes(2 on each size). There is then 2 copper tubes/pipes going thru the booth that are connected to eachother on the sides. To the right is my oven that I use for powdercoating. ![]() Here is a picture of some parts that are in the oven.
Hey guys,
Here's my set up, first the dbl oven, the bottom for pre-heat and the top for curing. Second My modified blast cabinet, it was a siphon unit, I switched it to gravity fed and added a halogen light inside, Third is my spray booth, its not pretty but gets the job done... [/img] |
hi
Im new at the powder coating thing, trying to get a business started. I got my whole workshop set up. Ill go take some pictures and post them later. Anyways, I have a pressure sandblaster (10gal) and it is not working, any ideas? The psi is up to spec everything is fine, maybe clogged up? Im using playsand, I know its bad for you. Im going to get rid of it and get some glass bead, maybe a new blaster. Recommendations for a portable blaster? Thanks. -Chris |
This subject is a great idea. I will post some pic's soon.
Good Luck Bob
www.capecodpowdercoating.com |
| Best Blasting Media process for polishing? | tomg552001 | Metal Polishing Questions | 5 | 12-23-2002 03:22 PM |
