Results 1 to 4 of 4
Thread: Clearcoat over Powdercoat
  1. #1
    57j2olds is offline New User
    Join Date
    Dec 2003
    Posts
    6
    Default Clearcoat over Powdercoat
    Hello,
    Could you please tell me if I can spray a clear coat (high temp spray can-paint) over my newly powdercoated valve covers? Will this harm the powder?
    I have a decal that I need to put on the valve cover and I wanted to clear over it to make sure it sticks well and to protect it.
    Thanks,
    57tripowerolds
  2. #2
    Fireblade is offline Amateur Metal Finisher
    Join Date
    May 2003
    Posts
    162
    you should be fine, people paint over powder all the time.
  3. #3
    Badger is offline New User
    Join Date
    Oct 2007
    Posts
    13
    Default Re: Clearcoat over Powdercoat
    Wow, on my other forum (PFF for those who might recognize the abbreviation ) this would have been archived looooooooooooong ago. Being new to this whole business, I was wondering the same thing myself. One of the issues that I noticed someone had a problem with was that they had a motorcycle part that was partly powder coated and part polished metal. There were responses that indicated that powder coaticon was not water proof, but I didn't see where anyone had mentioned recommending using a clear coat over the powder.
    What kind of guidelines do you guys go by when deciding when or not to use a clear coat?
    I've spent some time replacing parts of my engine and engine compartment with powder coated parts...
    and wonder if I should have taken the time to clear coat them? It certainly seems to make sense if it's a part that will be exposed to the elements such as a side mirror for instance...
  4. #4
    corecoatings is offline Amateur Metal Finisher
    Join Date
    Dec 2004
    Location
    Freedom Vale
    Posts
    88
    Thumbs up Re: Clearcoat over Powdercoat
    I did spray bomb clear coat over powder coatingicon on a friends rims. It works surprisingly well.
Thread Information
Users Browsing this Thread
  1. Stripping powdercoat
    By Billet in forum Metal Polishing Questions
    Last Post: 01-12-2005, 12:39 AM
  2. Can you powdercoat over powdercoat?
    By gopedhead in forum Powder Coating Questions
    Last Post: 12-14-2003, 06:17 PM
  3. Best Clearcoat For Polished Steel
    By z9ertek in forum Metal Polishing Questions
    Last Post: 11-05-2003, 05:52 PM
  4. VHT NU-Cast Alu and clearcoat
    By daobra in forum Other Metal Finishing Questions
    Last Post: 03-22-2003, 06:57 AM
  5. Types of clearcoat
    By marsfrogie in forum Metal Polishing Questions
    Last Post: 01-31-2003, 06:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
