Old 04-16-2002, 01:41 PM
hubahuba
Default removing powder coating
I have some aluminum parts that I want to polish, but they are powder coated. Whats the best and easiest way to do this from a garage/home stand point. The parts vary from 8" long by 3-5" wide.
Old 04-16-2002, 09:01 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: removing powder coating
Sandblasting would be the easiest way. Buffing with an abrasive wheel would be the cheapest way, if you don't have a sandblaster.
Have A Web Site?
Old 04-17-2002, 02:31 PM
hubahuba
I don't have a sandblaster and I do have the abrasive wheels. Some of the parts have nooks and crannies on them that the wheel won't reach. Won't heating the powder coating up then stipping it some way be easier?
Old 04-18-2002, 09:52 AM
mcaswell's Avatar
Caswell Inc Founder
We sell a product called "Clear Coat Remover" that will chemically strip the powder coat. No heating of the part required.
Have A Web Site?
Old 05-19-2002, 12:06 PM
chazmania006
Will your clear coat remover work on powder coated zinc/pot metal parts? or will it attack the softer metal?
Old 05-21-2002, 03:48 PM
mcaswell's Avatar
Caswell Inc Founder
Should be fine. It won't attack the metal.
Have A Web Site?
Old 01-12-2003, 02:02 AM
tomg552001
Send a message via AIM to tomg552001
I have a few questions about stripping powder coating.
1) How large is the container of clear coat remover you sell, it dosnt say, does it contain caustic chemicals like normal automotive paint stripper, and can you guarentee it will strip powder coating?
2) What type of abrasive and grit do you suggest using to remove the powder coating if using a blasting cabinet? (IE 30 grit alum oxide, course grit glass bead, walnut shells etc)
Thanks for the help.
  #8 (permalink)
Old 01-13-2003, 10:51 AM
mcaswell's Avatar
Caswell Inc Founder
Its a quart. No we can't guarantee it will strip the powder. Depends how
thick it is.
It depends what sort of surface you want as a finish. I'd suggest a 120- 180 aluminum oxide. Walnut shells/glass bead are really more for polishing.
Have A Web Site?
  #9 (permalink)
Old 04-30-2003, 05:29 PM
prins
Default removing coating from Rims
What is the best way to remove the alloy coating from my aluminum rims? is there any chemical i can use it in my home ? if there is a chemical available, will it give a good shine on my aluminum wheels after removing the alloy coating? please advise
  #10 (permalink)
Old 04-30-2003, 05:58 PM
mcaswell's Avatar
Caswell Inc Founder
Do you mean the clearcoat, or the anodized layer?
We sell both a clearcoat remover and an anodize stripper. See http://www.caswellplating.com
Have A Web Site?
*** WE ARE GIVING AWAY FREE POWDER COATING *** mcaswell Powder Coating Questions 197 07-08-2008 01:31 PM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 09:15 AM
Powder coating on firearms LoneGunman Powder Coating Questions 2 06-15-2006 01:54 PM
Non-paint powder coating dshepherd Powder Coating Questions 6 01-26-2004 12:49 PM
Removing powder coating? jagrc Powder Coating Questions 3 12-23-2003 09:51 AM
