what exactly is the reason for a clear coat? just for shine? Im going to powder coat a set of stock wheels on my motorcar and I plan on using a
Nickel Gold Metallic Polyester Flat, would I need a clear coat over this? |
do most powder coats fade without a clear coat? would you recommend putting a clear coat over the "Nickel Gold Metallic Polyester Flat" seeing how this is a wheel and takes alot of wear and tear will it make it more durable?
If the gold you are using is a exterior coating then it will be fine, but a clear coat on anything will help the durability, since you have two coats to go through not just one. If you are using a flat gold, then you would want a flat clear as well. One more thing, if you decide to use the flat clear, spray a test piece with the gold then the clear, sometimes the color will change dramatically, and your gold that you liked may be something now you don't like.
I asked this in a different thread, but was curious if it might get other opinions here in the powdercoating forum. Have any of you tried using clear powdercoating over an anodized surface, to use as a protective coating to prevent damage from rock chips, etc. ?
Have you had any problems with paint adhesion to the polished surface? Being a smooth surface I thought that the paint wouldn't get a good bite on the metal.
I've been wanting to try clear coating polished aluminum. Gary |
Is there a preferred way to clear over the chrome powder? Thanks, Walt |
| metallic coatings, need top coat? | corybarta | Powder Coating Questions | 10 | 03-21-2005 01:08 AM |
| Candy top coat cracked | ricelake | Powder Coating Questions | 4 | 02-19-2005 07:04 AM |
| Clear coat problem | sportster883r | Powder Coating Questions | 3 | 11-21-2004 05:52 PM |
| Powder Coat caught on fire! | Sleepr_Tech | Powder Coating Questions | 3 | 09-10-2004 07:22 AM |
| Second coat after a few days | tcjm | Powder Coating Questions | 1 | 03-20-2004 01:36 AM |
