Old 02-25-2004, 10:40 AM
etyrrany
Default Symptom & Solution
Hi,
During the past weekend I was experimenting a bit. I was doing a mirror chrome base and a candy teal top coat and I got a bit of an error. The metal substrate is a section of chromemoly steel pipe that I salvaged from my now defunct bicycle.
The process was to strip the old paint, sandblast with Alum Oxide at 90PSI and clean with IPA and shoot with Mirror Chrome powder. Note, the part was not pre-heated! The part was baked/cured at 375°F for 20 min. Then let air cool for 5min and shoot with Candy Teal which was baked/cured at 350°F for 20min.
This is the result I got:
The areas circled with the red I know what that is. That is the left over lint from the blue shop towels that I used to degrease with IPA. The rest of the little craters I have no idea that it is. Since this is a ferrous metal I am assuming that you do not have to outgas. The little craters do not look like they are they typical outgas problem. I believe that the little craters were evident after the Mirror Chrome was shot but I am not 100% positive. I only noticed them after shooting with the Candy Teal.
I did another sample with the same metal. This included a polished section of pipe that I shot with just Candy Blue and even without preheating it came out flawless.
So my question is what is it and how can it be prevented.
Thanks,
etyrrany
Old 02-25-2004, 03:50 PM
Fireblade
You did not preheat the bad part right? Are you sure the IPA (whatever that is) was dryed completely? I did this once before, it was on polished aluminum, and I used acetone trying to clean the surface. I think the acetone was not completely gone before I applied the powder. Same results as you, did you wait longer with the piece that came out good before you spryaed it?
Old 02-25-2004, 04:13 PM
etyrrany
Fireblade,
I didn't preheat both parts. I should have mentioned this earlier but the only difference between the bad part and the good part is that the good part was blown off with compressed air to get rid of the lint from the blue towels I was using to degrease.
Also, IPA = IsoPropyl Alcohol.
Thanks,
etyrrany
Old 02-25-2004, 08:33 PM
Fireblade
Well, looking at it more, it may be that you were thin with the candy teal as well. Hard to really say, anybody else any ideas?
Old 02-25-2004, 09:16 PM
tomg552001
Send a message via AIM to tomg552001
Thats a really funky problem you got there. It's almost like reverse back ionization . I am clueless.
Old 02-25-2004, 10:05 PM
WAORacing
well since you said that you blew the part off with compressed air my guess is that it could be moisture and that did not dry before you sprayed the teal. I did a part that ended up having lint in it after i cured it with the chrome. I took a razor blade cut the lint off not digging into or cutting the finish and then i cleared it and cured that. You could still see minor imperfections but not as noticeable as it was to begin with.
Old 02-26-2004, 11:51 AM
etyrrany,
Doing a 2 stage on chromemoly, you might want to partially cure the first stage then shoot the second stage and do a full curing cycle. In other words bake it till it flows out and just begins to cure, then take it out let it partially cool and shoot it with the candy, then put it back in for a full cure cycle. The double cure time could be causing some sort of seperation of the alloys used to make the bicycle frame. Just a guess on my part but I figure it's worth a try.
  #8 (permalink)
Old 02-26-2004, 12:19 PM
etyrrany
Thanks alot everybody.
I have lots more of these "sample" pipes available so I will try to solve this in the future.
So far I will try is:
1. Blowing off the blue lint.
2. Pre-heating (even if slightly but enough to evaporate all of my degreaser).
3. Partial Cure on base color.
Too bad I don't have alot of time cause I could attack this in true scinetific style and start isolating each variable till I find the solution. For now as long as I solve it I'll be happy.
Thanks,
etyrrany
  #9 (permalink)
Old 02-26-2004, 03:33 PM
non-stick
it certainly appears to me like you may have quite a few things going on there all at once and not one singular specific problem. I most definately see "solvent popping" ( where all of the solvent is not completely dry and/or leaves a residue underneath your coating ) and it looks like an unusual amount of airborne particulate stuck on your part.
gold plating solution gone bad?????? anyone from there ?? clocktools Electroplating Questions 2 08-21-2008 07:44 PM
trouble plating with 18K fast gold solution didierphmartin Electroplating Questions 2 05-06-2008 03:51 PM
Temperature of Caswell gold solution apricotscrub Electroplating Questions 0 03-13-2004 07:36 PM
I know your gold plating solution is cyanide free, but... tbloss001 Electroplating Questions 1 07-30-2003 03:23 PM
14k gold solution Rusty Armstrong Electroplating Questions 1 04-05-2002 11:23 PM
