FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 03-27-2004, 05:38 PM
Noob2PC's Avatar
Noob2PC
Default Sandblasting ???
Does the medium you use for sand blasting make a difference? I used clean play ground sand and it worked ok I guess. This is my first time and I felt it should have worked better. I had my pressure set for 100. My cabinet I made worked grea though!!!
Old 03-27-2004, 08:28 PM
dagobert
Yeah, it can make a difference, but the key to it is what you are trying to use it on. For striping, a good Aluminum Oxide like a 120 grit is a good choice, unless it is a soft surface. Then, you can step down from glass bead to walnut shells, and some people even have success using talcum powder for really fine finishes. There are a lot of people on here more knowledgable than I am to ask, but compared to the playground grade sand, I think you'd be happier with other options. Best of luck with it.
Old 03-27-2004, 09:18 PM
Noob2PC's Avatar
Noob2PC
Guess Im glad it was given to me then will check out other options
Old 03-28-2004, 01:00 AM
skiddz's Avatar
skiddz
Lose the playground sand. It's got a very high silica content and can lead to silicosis (fills your lungs with scar tissue) if you breathe the dust. At a very minimum, get yourself a decent respirator or switch to coal slag or aluminum oxide.
I blast Aluminum Oxide and glass bead and *always* use a half-mask respirator.
SANDBLASTING Sezer Powder Coating Questions 6 06-15-2005 10:28 PM
Sandblasting and polishing. schwartzyjaimy Other Metal Finishing Questions 0 11-10-2004 10:12 PM
SandBlasting Cabinet----L@@K johnny933 Powder Coating Questions 16 05-18-2004 10:19 PM
question on sandblasting off chrome hearse71 Metal Polishing Questions 1 04-11-2003 09:08 AM
sandblasting foumer Electroplating Questions 1 01-16-2002 11:33 PM
