blade you will not get the gas out of it .. i pour alum.. and i it is melted down lawnmowers and carbs... and what not .. i get the little pin hole in the casting to ... no matter what i do they come back... it may be the flux i use to ... but each part is washed 5 times before it go's in the melting pot and i skim the crude off till i get a clean pot .... i will do some looking in to it and keep you posted
i tryed to do a door handle ... it was bad ... i just spray the with self etching primer the top coat them .... the stuff i put in the lathe may be good for anodizing .... but there may be a cure ... pryo putty make work ... i will give it a shot ....
I'm having a tough time with MR Gasket Carb adapters. I had to do a 2nd coat on one and it outgassed bad, I mean hell, they were not there the 1st coat. The other one I even preheated and it still outgassed on me. Oh well, live and learn, off to ebay those 2 go
For cast aluminum I try to get customers to go with a textured powder, it hides most everything. Also try outgassing your part for a rediculous amount of time, you can't go to long. Most people stop around 30 min or less.
| clear coating polished alum | hybred | Metal Polishing Questions | 7 | 08-08-2005 03:58 PM |
| powder of polished alum? | hybred | Powder Coating Questions | 3 | 08-07-2005 03:38 PM |
| Problems with cast alum | sswee | Anodizing Questions | 5 | 07-13-2005 07:13 PM |
| paint removal on alum. | customandsound | Metal Polishing Questions | 5 | 01-16-2004 08:40 PM |
| cast alum ?'s for the new guy. | 8knots | Anodizing Questions | 4 | 11-20-2003 01:16 AM |
