How close is the light to the part? How long did you leave the part under the light. Is it a dense part? What is the part made of? Unfortunately IR curing isn't cut and dry. If you're curing a thick steel or aluminum parts, you might want to keep the lamp very close and leave it there for a long while. Powder flowout begins with part temp, and it might take a long time to heat the parts. Also make sure that your lamp is pointed perpendicular to the part. IR moves in straight lines.
LinkBack URL
About LinkBacks
