Old 05-03-2004, 10:07 PM
Blademan's Avatar
Blademan is on a distinguished road
Default hi-temp silicon
While back I asked if you could use Hi- temp silicon in the squezzzzze tube for masking...this is the responce I recieved back from Loc-tite...
Wayne,
Thank you for your inquiry. While the high-temperature silicone will
withstand the temperature, the adhesion may be more than you want. You can
try it, but often baking a silicone can make it tougher to remove later.
Mineral spirits can be used to swell up a cured silicone to remove it.
Regards,
Cathy
so now ..I gotta play.....
Old 05-05-2004, 11:48 PM
Silicon will contaminate most powders and ruin the final finish.Manufacturers recommend storing epoxy,urethane, or polyester in a silicon free environment. Good luck but don't be suprised if it works as a mask but contaminates the near by powder.
Old 05-07-2004, 07:34 AM
Blademan's Avatar
Thanks Dale...I was just looking for a quick way to mask off letters..guess theres no sub for just doing it right .
Oven temp vs part temp getastro Powder Coating Questions 4 10-01-2007 12:53 AM
Emissivity setting for IR temp. LouisT Powder Coating Questions 0 05-16-2005 12:04 AM
IR Temp Probes getastro Powder Coating Questions 3 07-21-2004 09:12 AM
Curing Temp... try2kechup Powder Coating Questions 5 05-10-2003 03:46 PM
Can I use VHT high Temp with Krylon High temp radiator paint magnus Other Metal Finishing Questions 1 05-03-2003 11:20 AM
