| View Poll Results: If Caswell got Teflon would you buy it? | |||
| Absolutely |
4 | 40.00% |
| Maybe |
4 | 40.00% |
| No |
2 | 20.00% |
| What is Teflon? |
0 | 0% |
| Voters: 10. You may not vote on this poll | |||
Where can I buy some Teflon coating at? I haven't seen any on Caswells and DuPont you have to order $1000 worth of the stuff to get any. Would be an excellent item for Caswell to start carrying. My Cold Steel knife is loosing its Teflon coat and I'd like to redo it.
We have to buy a minimum of 4 cans when we restock, at around $300.00 to $400.00 per can (1 gallon). The co. we buy from (in K.C.) is Entech, but I'm not sure of that spelling, I'll have to check.
1 gallon lasts a long time even for us. Also consider it has a shelf life of about 1 year, and is destroyed upon freezing. There are also different grades of Teflon. Not all of it is food grade, and several types require a wash primer as well. Curing temps vary from around 400 to 600 F. Some of these require the use of DuPont's thinners for clean-up, and only their thinners can be used for thinning (no substitution). You might check Teflon.com for MSD sheets to make sure you even want to handle this stuff as most of these thinners make MEK look passive. We use a special plastic (disposable) glove when handling it, if you like, I'll find out where we get those too. I have been told that it is also available in powder form, however we shoot the liquid, and, it requires a sandblasted finish for proper adhesion. There is another company in town that uses the powder combined with an acid etch that we have been told is inferior to the sandblast prep we do. I realize its not a factor right now with summer coming on, but after around the first of October shipping rates go up because they have to ship by heated truck(for liquid). |
| Powder coating on firearms | LoneGunman | Powder Coating Questions | 2 | 06-15-2006 12:54 PM |
| Removal of unknown coating on aluminum | rclint | Metal Polishing Questions | 6 | 08-25-2005 12:04 AM |
| Coating Brake Rotors | rickanderson53 | Other Metal Finishing Questions | 4 | 08-18-2005 11:15 PM |
| Non-paint powder coating | dshepherd | Powder Coating Questions | 6 | 01-26-2004 11:49 AM |
| Does a coating exist that can be bent slightly? | Augest | Powder Coating Questions | 1 | 09-22-2003 01:34 PM |
