try turning it up on the toaster oven as high as it will go but just keep a close eye on it with the IR thermometer. And see if that helps to get the temp up quicker. It seems like aluminuim takes a little longer to get up to temp. Oh when or if the part does reach the temp recomended for the powder then turn it down and try to keep it consistant.
Ok, put the part in the oven and set the temperature to Broil which is its highest setting. Checked the parts temp after about 5-10 minutes with the part still in the oven it read 450 degrees F. I pulled the piece out of the oven and immediatly checked the temperature again and it was like 200 degrees. This makes no sense I don't believe the temperature could of dropped over 200 degrees in that small amount of time...kind of confusing any help is welcome.
At the shop i got a nice oven at home i got the poorman setup ... i use a toaster oven .. i use it for small stuff like blademan .. bolt's water neck's ect... depending on the temp on the outside it work's ok but not the best .. ised a heat gut to flow out powder the other day ... it worked just as good as a toaster ... i think i will be driving around on trash day and yanking a oven out of the trash ...
That's what I did. I found a nice over 'N under double oven on the curb on trash day. Free is a good price. I removed the range top and burner elements so it's just like a counter top. When it's not being used, I keep my powder gun there. It's nice being able to cure using both ovens at the same time.
Hemi-T |
| PLATING POT METAL............... | 48Buick | Plating Pot Metal | 35 | 11-10-2009 10:25 PM |
| metal prep question | corybarta | Powder Coating Questions | 2 | 03-09-2005 02:49 PM |
| Plating already anodized metal question.. | qwik3r | Electroplating Questions | 2 | 02-15-2004 05:16 AM |
| Lab metal question | NeoMoses | Anodizing Questions | 6 | 12-13-2003 07:33 PM |
| Refinishing Metal Golf Club Heads | BillSchultz | Other Metal Finishing Questions | 0 | 08-17-2003 11:40 AM |
