Old 06-09-2004, 09:35 PM
boucher
Default doing two colors help
the steps i did for doing two colors 1.prep part 2. taped part with high temp tape 3. sprayed part 4. baked part for about 3-5 min. after it started to flow. 5. when part was cool peeled tape off and put tape on all the painted surfaces 6.sprayed part 7.baked part for about 3-5 min. after it started to flow.8.let part cool removed tape and baked for 20 min@380-400 the problem i have i see and feel all the tape marks placed over the first color what did i do wrong??
Old 06-09-2004, 11:50 PM
Bud Bud is offline
Bud
I think after you spray the second color on the part you need to remove the tape before you put it in the oven so don't do step 7. All your doing is heating the powdercoating up underneath where the tape is and it is leaving tape marks because the powdercoating was no longer hard.
Old 06-15-2004, 04:02 AM
Carcher7878
Send a message via AIM to Carcher7878 Send a message via Yahoo to Carcher7878
Ya know, I did this with my fuel tank off of my 900RR. I coated the whole thing Black Chrome, then I masked it off and coated it with a Black mini texture powder. Took off the masking and started curing. So where I had the tape, I could see lines on the blk chrome. I dont understand it at all. So I coated the whole thing in the blk mini tex, and fubared it all... the tank held so much heat, I have to move the curing lamp every 4 mins. I mean i know the powder wasnt curing, BUT it was reaching 500 degrees in less than 5 mins.
1) I dont need the steel to warp
2) really dont want the powder to OVER CURE from too high of a temp..
SO I had to restrip it and it DID NOT cure all the way... instead of wrinkle rubber like it normally does with a strip, it was a dripping gel mess!!! AND metal filler just heated up like nothing. and it bubbled the powder... UGH... Guess I have to paint the tank...
Old 06-17-2004, 11:41 AM
Unfortunately really nice paint scemes are best left to paint and reserve the powder for single color or fades. Fine line art work is a B*&ch with powder.Plus with paint you can go as wild as your imagination can go.
Old 06-23-2004, 04:58 AM
drfjr1976
Try curing the first coat completely, tape off the area you don't want coated with the second color, spray, than cure. Remove the tape than apply a clear over the entire piece and cure. Try it on some scrap and see if it is to your liking. Seems to work pretty good for me.
Old 06-23-2004, 04:55 PM
WAORacing
That is the steps that i followed and when i pulled the tape of after the second cure it left imprints in the first coat. What's up with that?
Old 06-24-2004, 02:15 AM
drfjr1976
Did you completly cure the first coat?
  #8 (permalink)
Old 06-24-2004, 08:22 PM
Blademan's Avatar
Blademan is on a distinguished road
I do..but that doesnt meen its right..
  #9 (permalink)
Old 06-25-2004, 09:38 PM
WAORacing
yes the first coat was completely cured.
  #10 (permalink)
Old 06-26-2004, 06:00 PM
Heres a thought, try static tape or low adhesion tape, it's plastic and adheres to parts by static only with no adhesive. Glue problem solved. Or cling wrapp for food on larger areas.
New Powder Colors, Sizes, and Technical Data mcaswell Powder Coating Questions 13 06-21-2007 01:16 PM
Flourescent Colors CaptainChauncy Powder Coating Questions 2 02-17-2005 06:21 PM
Need help..... Looking for Arctic Cat colors Sleepr_Tech Powder Coating Questions 0 08-02-2004 08:49 PM
Problems with clear, flowout, multiple colors, more... allcarfan Powder Coating Questions 3 08-25-2003 10:49 PM
Three New Colors mcaswell Powder Coating Questions 0 02-25-2003 02:00 PM
