Hi,
I just p.c. a Harley frame mirror black. The tube's come out great but the heavy plates were the swing arm attatches was a bit orange peeled. I don't think the powder was any heavier in that area. Should I try to pre heat longer, high cure temp? Any idea's? Thanks, Art |
I'm assuming you blasted the frame.All frames done in my shop get hand sanded quickly with 400 grit paper, this really helps on the plates and brackets.Don't spend alot of time sanding just remove the high spots left from blasting.Preheating longer only helps with outgassing and fisheyes.Going with a higher temp will probably only make the problem worse(it gives the powder less time to flow).
All frames here are baked at 375 but 400 is fine too.Try the hand sand and clean well (don't forget a good hose rinse not a bucket and sponge rinse).The smoother the metal the better if you are really after a mirror,just don't polish it to a shine prior to powdering.
| PC'ing an old truck frame... | dansilbaugh | Powder Coating Questions | 5 | 07-22-2005 05:11 PM |
| Frame polishing....same process...2 different finishes? HELP | bairdmotorcycles | Metal Polishing Questions | 15 | 06-27-2005 04:13 PM |
| polishing frame | shaybirde | Metal Polishing Questions | 4 | 04-24-2005 12:18 AM |
| anyone done a harley frame | sickboy57 | Powder Coating Questions | 0 | 03-13-2005 05:49 AM |
| Frame Polishing Question | SICKGIXX | Metal Polishing Questions | 10 | 03-18-2003 11:50 AM |
