Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 06-15-2004, 06:18 PM
johnny933
Default IR Curing--------------LOST
Im a little lost on this. I've been using the m1500 to cure parts and all
is going well.........I think. I got a reflective shield opposite the light.
Im lost on this. Parts look done after cure time recommend but IR temp. guage only says there at about 240 degress. Is the rays from the light effecting the ir gun?
ANY INPUT APPRECIATED!!!!!!!!!!!!1
Thanks
Old 06-17-2004, 11:29 AM
If you think it's the light screwing up your reading,then click light off and measure temp quickly,then turn light back on. Here's a thought- Try a sample peice and once cured try to damage coating.See if it is hard and attached well.Under cured powder is usually easier to remove. Any of you IR guys feel free to chime in and help.
Closed Thread
Curing Lamps asallwey Powder Coating Questions 3 09-30-2004 08:36 PM
Curing powder coat tomg552001 Powder Coating Questions 17 05-18-2004 06:57 PM
Infrared curing question linnracing Powder Coating Questions 8 12-20-2003 01:41 PM
Curing question tomg552001 Powder Coating Questions 2 07-12-2003 12:54 AM
Curing Temp... try2kechup Powder Coating Questions 5 05-10-2003 04:46 PM
