Old 06-18-2004, 07:59 PM
Blademan's Avatar
Blademan is on a distinguished road
Default grit
How the hell do you guys get all the sand out of the crevices on valve covers 175 psi dont get ...washing doesnt get it...both in several process's hasnt got it...I even fasionded a pick ....this is getting frustrating...
thanks
Wayne
Old 06-18-2004, 10:02 PM
etyrrany
What do you mean by grit? Left over sand blasting grit? If so you may have moisture in your air lines and sandblasting requires dry air so you don't get this grit.
You may need an air dryer on your compressor.
etyrrany
Old 06-18-2004, 11:22 PM
customandsound
Guest
Posts: n/a
i use alot of air and a nozzle that you fill up ball's . i brazed it to a quick connect .. it work good at getting in the tight spot's
Grit sizes mpierich Metal Polishing Questions 3 03-04-2005 11:04 AM
Which Grit Media to get? Noob2PC Powder Coating Questions 1 04-12-2004 09:13 PM
40 Grit expander wheel belts JamesC Metal Polishing Questions 0 11-18-2003 09:19 PM
Tiny scratches revisited VTXer Metal Polishing Questions 27 10-04-2003 10:32 AM
Should i be using a smaller grit? fosgate99 Metal Polishing Questions 2 11-14-2002 10:40 PM
