Old 07-01-2004, 06:22 PM
Millermatic
Default Chrome / Candy
I know this has probably been repeatedly covered, but I could use a little clarification. I want to use chrome poly as a base, then top with candy red. What is the exact cure schedule for each and is there anything that needs to be done to the part in between coats? Thanks in advance
Old 07-01-2004, 07:24 PM
getastro's Avatar
getastro
Cure the chrome for half of the full cure time, let part cool down then spray candy color. Cure at full temp and time. Done
Old 07-02-2004, 07:28 PM
Millermatic
I'll give it a shot, thanks for the info.
Old 07-03-2004, 07:25 PM
Millermatic
It didn't work...for whatever reason, the chrome came out great, it cooled, then when I went to apply to candy, it wouldn't stick to the chrome. Help?
Old 07-04-2004, 01:10 PM
getastro's Avatar
getastro
If you are using a hobby style gun, try spraying the second coat when the part is warm. this should make the second coat hold. just watch how much you spray, you can over coat the part by doing it this way.
Old 07-05-2004, 01:12 AM
WAORacing
Sounds like you didnt have good ground to me. I have had to try several different pieces to get use to shooting the translucents myself. They seem do seem to alittle more difficult to get the right amount applied, so you dont get any bleed through of the chrome or to much build on the corners to where you can see a color difference. Just practice is all i can say.
Old 07-05-2004, 11:46 AM
Noob2PC's Avatar
Noob2PC
I have a piece that I have shot 3 times and still need to shoot it again (don't Ask ). But I have never had any problem with powder sticking on the 2nd or 3rd coat.
  #8 (permalink)
Old 07-28-2004, 01:22 AM
upncoming's Avatar
upncoming
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
how many times can you PC the same part?
D.I.L.U.S.I.
Drive It Like You Stole It
  #9 (permalink)
Old 07-28-2004, 08:51 AM
For those of you who are having trouble getting the candy/translucent colors to stick switch from chrome to silver. it's a little darker (not much) but coats much easier.
  #10 (permalink)
Old 07-28-2004, 06:07 PM
upncoming's Avatar
upncoming
will the translucent look as good as the crome base when you use the silver ?
D.I.L.U.S.I.
copy chrome vs triple chrome plating splbnd27 Electroplating Questions 18 06-21-2006 07:35 AM
Copy Chrome Start-up Elitefisherman Electroplating Questions 10 04-18-2004 04:24 AM
Copy Chrome Questions junodale Electroplating Questions 13 03-17-2004 11:15 AM
Chrome (re)plating question - howto olaf_sc Electroplating Questions 1 07-29-2003 02:00 PM
Hard chrome vs triple chrome butters Electroplating Questions 1 02-19-2003 11:35 PM
