I have done spot checks on a lot of the parts I pull out of the oven at 400, given that the parts have been coated the digital laser never comes close to 400 on a standard 20 min dwell time. More time and accurate temp measurements test, test.
Allot of things can effect the IR temp meters. Angle pointed, distance, perhaps even color of part and reflection for readings. Also if battery is low you will get a false reading allot.
I have noticed a correct reading NOT using the red laser, and a far too low reading after I turned on the Laser, replaced the battery and all was fine again either way. Same thing with the display back light using it at night and the battery a bit low. I like my IR thermometer for many things, but it takes playing with sometimes to be sure a reading is the highest or correct. Basically I figure not much reason for a reading to ever be too high, but lots of reasons for it to be too low, so I check allot of ways like various angles and distances. Usually I trust the highest reading, and certainly if it's close to some other reading like a real thermometer or one of those shelf type oven thermometers. |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 04:43 PM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 06:21 PM |
| OVEN | 11111111 | Powder Coating Questions | 18 | 11-06-2004 04:16 PM |
