In the field of audio power amplifiers, heat is dissipated by the use of huge aluminum heat sinks.
1. Does powder coating alumninum decreases the heat transfer rate when compared to bare aluminum? 2. What about anodizing. Does this also decrease the heat transfer rate when compared to bare aluminum? The difference in heat transfer rates may be insignificant to be of any concern but I am curious. Thanks |
Sorry - don't have any information about that.
I'm curious about this as well.
If I were to anodize a piece of a aluminum whose purpose was to transfer heat (intercooler), would the aluminum's ability to dissipate it decrease because of the coated surface? I'd assume it would be, but I'd like to know for sure. Any one in the know, please let me know! -Tyler |
When I Powder Coat lets say a Complete Engine, the temp on the engine will raise about 10 degrees over normal. So what I do drop the T-Stat by 10 degrees to help off set. How do I come to the above figure? Well run 2 engines of the same size and make and same cond. The PC 1 will heat faster ( Normally staying about 10 degrees ahead of the uncoated one) then the un-coated engine and will run about 10 degrees higher +/- a few degrees. Not sure of teh Temp rise or ins factor for the heat sink. Also have no answer for the anodizing.. But I'm sure it does as your covering teh bare metals.. Jim S...
Jim Shuster www.backyardpowdercoating.com Sold..... www.chrissys68mustang.com Hobbie www.photogserver.net Web Hosting. |
Like Hvac said, Powder does reduce the heat transfer. Anno does a little too, but not any measureable amount. I have seen alot of heatsinks for various thengs anno's. Heck, all car audio amplifiers are anno'd. My RC car's Nitro engine heatsinks are anno. I have removed the anno before and have seen no measureable effects on the temp of the engine. The engines run at approx 230-260F
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
Well I guess I'll chime in as well. I did a search on heat transmission and submission of annodized aluminuim. I don't completely understand the science behind what the engineers said but the jist is that paint and powder will in most conditions act like an insulator as will aonodizing. However in most conditions anodizing is preferred because any bare aluminum that is exposed will begin to corrode. The natural corrosion will have much higher insulation properties than even paint will have depending on the thickness. Also the conditions are very important. In some cases it is better to anodize or powder coat, such as in a high IR environment, because the insulating properties will actually help keep temps even. In a convection or conduction environment it can create problems if you heat tolerances are very tight. Also in the examples given, color could also play a role in both methods of coating. This is a very interesting and confusing subject, because you would naturally think that the rules of heat transfer would be consistant, but according to some of the thermal dynamics engineers the rules change with every variable.
| ?1) blast cabinet replacement part ?2) exhaust heat shields | upncoming | Powder Coating Questions | 4 | 03-21-2005 12:33 PM |
| Question on heat transfer on final part. | hellos | Electroplating Questions | 3 | 06-26-2004 03:54 PM |
| heat treated aluminum | warchild | Powder Coating Questions | 2 | 10-25-2003 08:58 PM |
| Heat Source | mitch_vinton | Powder Coating Questions | 1 | 07-31-2002 10:35 PM |
| Heat effects on Chrome | nunnc | Electroplating Questions | 1 | 06-16-2002 10:55 PM |
